AMP Q's for da n00b again :)
Old Oct 3, 2002 | 08:13 PM
ZeroEric's Avatar
Default AMP Q's for da n00b again :)
Ok, I asked earlier what I should geet for a setup... since my inside bumps pretty nicely I'm not gonna get a 4 channel amp... I was thinking two sony 12's (4 ohms each...) but I wanted to know more of an amp... The sony's are 50-300w rms and I was wondering what that's all about... Would a 300w amp blow them since they are 50-300 or the subs just let anything between 50 and 300 push them?
Would the Sony XM-2150GSX 760 Watt 2/1 channel amplifier that runs 150 x 2 into 4 ohms be a decent amp to push those??? I want something that pushes the 50-300 x 2 and not x 1 since I'd be running two subs, right? I'm an amp and sub n00b... I'm trying to make sense of it and your guyses help is totally appreciated! Also, i dunno if it'd be safe or not but how can I run the 150x2 into 2 ohms for a 300x2 into 2 ohms and would that be ok with 4 ohm subs? I don't think it would but I dunno, I'm n00b y0!
Thanks guys! Tech
Old Oct 4, 2002 | 08:18 PM
ZeroEric's Avatar
Default Re: AMP Q's for da n00b again :) (iviZeRoCooLivi)
TTT, unless you guys are morons, and I know you're not This si basica audio stuff that I don't understand and I want to know so I have a basica idea of what I need to make sense of things...
Old Oct 4, 2002 | 09:54 PM
incubus's Avatar
first off sony subs suck. I used to work at best buy and people were the least satisfied with them out of all the subs we carried. 2nd the sony x-plod series amps burn up too easily. (eq probs on the '01 models) third if u r going to get that sony amp or amy 2 channel for that matter get 8OHM subs! not 4 ohms! if u want to get the most bang for your buck and get the most out of your 2ch amp you need to bridge it when you bridge an amp using 2 4ohm subs u will get a 2 ohm load. you want to run a 4 ohm load (4 ohm = standard load). if u take the same amp and run two 8 ohm subs in parallel you will be running a 4 ohm load which is what you want, by running two 8ohm subs in parallel you will keep your amp from overheating, and keep the distortion level down, plus a whole other slew of advantages... blah blah blah
here is a link for a good on-line store with bad-*** prices http://www.carmedia1.com
check out the clearance area they have an awesome phoenix gold amp for dirt cheap, 199 i think 10x better than sonys.
Old Oct 5, 2002 | 11:29 AM
ZeroEric's Avatar
Default Re: AMP Q's for da n00b again :) (incubus)
Cool thanks man! opinions are best
Old Oct 5, 2002 | 07:55 PM
clm_Sol's Avatar
Here's a really good website to look at if you want to learn more about car audio and electronics in general. I give it a .
http://www.eatel.net/~amptech/elecdisc/caraudio.htm
///Nick
Audio / Security / Video
May 3, 2011 11:19 AM
imadigitalgod
18
May 13, 2008 04:00 PM
Orpheus1985
Jul 21, 2005 07:15 AM
LuDeS
Nov 23, 2001 06:07 PM
