Free Shipping!!! Bisimoto Heat Shielding Intake Gasket Special
A special high temperature insulating gasket which replaces the factory intake gasket. Reusable, this gasket isolates the intake from head generated by the engine, allowing for a denser intake charge(50 Degrees cooler), and over 7-10 whp as documented in house. A favorite amongst road racers, drag engine builders, and street enthusiasts.
Does not affect emissions, and easy to install. A simple power adder
$48 Shipped anywhere in the Continental 48 States
We have these available for these motors:
B16, B18C5
B18C1
D16A1, A9 and ZC
D16A6, D15B1/2/7
D16Y8 and D16Y
D16Z6
F22a, F22b (non-vtec), H23
F22B2, F22B VTEC, F23 VTEC
H22 & F20B
K20a, K20a2, K20z1, K20A3
Heat sheiding intake gaskets, made from the proper high temp phenolic materials, alienate the heat of the engine from the intake manifold. This resuable gasket allows for a cooler intake charge, and hence, resulting in power increases in all motor and boosted applications. This Bisimoto gasket is used in all in house build.
Monday Bump!
Available For:
B16, B18C5
B18C1
D16A1, A9 and ZC
D16A6, D15B1/2/7
D16Y8 and D16Y
D16Z6
H22 & F20B
A special high temperature insulating gasket which replaces the factory intake gasket. Reusable, this gasket isolates the intake from heat generated by the engine, allowing for a denser intake charge, and over 5-10 whp. A favorite amongst road racers, drag engine builders, and street enthusiasts.
A simple power adder, indeed.
B16, B18C5
B18C1
D16A1, A9 and ZC
D16A6, D15B1/2/7
D16Y8 and D16Y
D16Z6
H22 & F20B
B16, B18C5
B18C1
D16A1, A9 and ZC
D16A6, D15B1/2/7
D16Y8 and D16Y
D16Z6
H22 & F20B
Bisimoto Engineering: Heat Shield Intake Gasket
Available For:
B16, B18C5
B18C1
D16A1, A9 and ZC
D16A6, D15B1/2/7
D16Y8 and D16Y
D16Z6
H22 & F20B
Does not affect emissions, and easy to install. A simple power adder!!!
B16, B18C5
B18C1
D16A1, A9 and ZC
D16A6, D15B1/2/7
D16Y8 and D16Y
D16Z6
H22 & F20B
B16, B18C5
B18C1
D16A1, A9 and ZC
D16A6, D15B1/2/7
D16Y8 and D16Y
D16Z6
H22 & F20B
