IMW-Tuned: 600whp stock block K20A2
Old Aug 30, 2011 | 04:45 PM
D-Rob's Avatar
Default IMW-Tuned: 600whp stock block K20A2
After going through some different stages with this car, I thought I'd share my latest venture with it -making three times the stock power output from my personal K20A2 engine.
The setup is as follows:
Stock bottom end K20A2
Stock head gasket
Stock head bolts
Stock cams
SuperTech valve springs and retainers
NGK BKR9EIX plugs
RBC intake manifold
Stock throttle body
Full-Race T3/V44 top mount manifold
T3/T67 H.O., .82 AR
TiAL 44mm wastegate
IMW-Spec 2.5" charge piping
IMW-Spec 3" fender-exit exhaust
Full-Race 1st Gen vertical intercooler
TiAL Q blow off valve
JS Manual boost controller
Stock EP3 transmission
Competition Clutch 1620 Series six puck clutch
Stock RSX-S flywheel
Walbro 255lph in-tank fuel pump
Bosch 044 in-line fuel pump
6AN fuel feed
Stock return line
Aeromotive FPR @ 43psi base
2000cc injectors
"Sheetz" pump E85
Hondata K-Pro
Here is the graph:
601whp / 424wtq @ 22.8psi
And some pictures of the car, for those that are unfamiliar with it.
I have driven the car a couple times on the street, and it feels pretty good so far. One of these days, I will get it down the track (between work, a new house, and a wedding coming up, my time is limited). I would like to see some mid-10 second passes at 135+mph, but I will be the first to admit that I can't drive to save my life. LOL. I also have two spare EP3 transmissions awaiting their time, like death row inmates.
I don't know what to expect from the car at the track, but it sure as hell should be pretty fun!
Thanks for taking a look!
- Derek
Old Aug 30, 2011 | 05:10 PM
nonvtecD's Avatar
Default Re: IMW-Tuned: 600whp stock block K20A2
Sweet.
Old Aug 30, 2011 | 05:28 PM
00Red_SiR's Avatar
All Motor Mentor
Derek....you and Marcel are making boost too tempting to say no....lol
Old Aug 30, 2011 | 06:12 PM
DDTECH's Avatar
Excellent numbers D!
Old Aug 30, 2011 | 06:16 PM
mtber's Avatar
I like how clean your floors are!
EJ1_Ex's Avatar
there is a local integra with the simlar setup that made the same amount of power!
D-Rob
K Series
103
Oct 30, 2015 05:56 PM
jasoncrashtech
Aug 1, 2014 09:19 AM
D-Rob
May 13, 2009 08:10 PM
rotascircuit
Dec 11, 2007 08:46 PM
a1320addict
Sep 16, 2004 06:40 PM
