Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Malfunction Indicator Lamp
Old Aug 30, 2011 | 09:42 AM
spartan85's Avatar
Default Malfunction Indicator Lamp
When driving to work heard a beep from dashboard and it was the 'Malfunction indicator lamp' had come on. Managed to get it to and from work ok, driving more carefully than usual.
Just had a service and MOT two weeks ago and passed no problem. The indicator comes up even when you put key in and stays on when turn ignition.
Could this be serious?
It is best to avoid using car until its sorted?
Old Aug 31, 2011 | 04:43 AM
Greg50Lt's Avatar
Default Re: Malfunction Indicator Lamp
It's just CEL. Go to autozone or local autoparts store. Tell them you have a check engine light and they will plug in the scanner and pull the code for free. Once it's pulled and you have info let us know what it was so we can give you advice.
Old Aug 31, 2011 | 06:49 AM
bee guz's Avatar
When you get it diagnosed for free (don't go to a dealer)ask what the problem is when they pull the code, get a price on the parts, then ask them to clear the code.
when you know how much the parts are it gives you an idea of how much the repair might cost without labor.
There are occasions when you just get a random code and there is nothing wrong, if the light comes back then you know it's time to have it repaired
Old Sep 2, 2011 | 06:31 AM
spartan85's Avatar
Just got car back from Honda garage, code was P2A00, internal air/fuel sensor fault. Was £93 for them to look at it (still under warranty so will get that back).
They think it could have just been a loose connection, as they took it for a quick drive and light is now off and has stayed off.
If i was to need a new sensor cost would be £238.72, so fingers crossed it doesn't come back on.
blaze.1
Sep 24, 2009 11:04 AM
8_UR_AWD
Honda Civic (2001 - 2005)
13
Mar 8, 2009 06:19 PM
EGTHU6
13
Nov 16, 2006 08:14 AM
JThrasher79
Dec 29, 2005 02:28 AM
picasso1
Jan 17, 2005 10:40 AM
