95 accord
Old Aug 30, 2011 | 08:50 AM
toliy21's Avatar
Default 95 accord
I have a 95 Accord 2.2 V-tec In may my compresor seized up after replacing the compresor and reciver/dryer the system was charged and wowrked fine for a month or so now it blows warm air, The cluth kicks on both fans working fine any one have any sugestions where to look next
Old Aug 30, 2011 | 03:34 PM
exb18c1's Avatar
Default Re: 95 accord
You probably have a leak somewhere,there is enough gas to activate the compressor but not enough to work properly.The only solution is to connect the gauges and monitor the pressures.
Old Aug 31, 2011 | 06:19 AM
StreetsideStig's Avatar
^Agreed. An auto parts store will have the refrigerant gauge.
Old Sep 5, 2011 | 07:49 PM
toliy21's Avatar
i hooked up the gauges the low side is at 90 the high side is at 95
Old Sep 6, 2011 | 01:01 AM
nus_dogg's Avatar
You have a leak like mine, but at the time of A/C recharge while doing this in Auto Tech class, we put in a dye into the A/C system. So now I will be able to look for the leak with a black light and a special glass or whatever you call it that you wear to find the leak.
Old Sep 6, 2011 | 04:04 AM
Steve Z's Avatar
You have a problem. Low side should be no where near 90 (more like 35) and high side is up at 185 or better depending on the ambient temp of course.
Old Sep 6, 2011 | 06:38 PM
exb18c1's Avatar
When you hooked up your gauges did you blast the system on?What are the fluctuations? the system has to run while taking the readings.The results that you posted looks like this is the static pressure(which is depending on ambient temperature is normal)-two sides(high and low) equalized.
sc300turbo
May 15, 2008 02:57 PM
pos95accord
Sep 5, 2006 04:31 PM
ashish_bhatta
Dec 21, 2001 09:32 AM
