Q31 HELP fried h22 turbo
Hi i have a civic 92-95 hb h22 turbo with aem water meth the runs perfect then I started to feel the vtec is not working and chek the ecu and q31 is fried then i change the ecu and do same thing fried q31 ,the car not bring the evap purge selenoid, my question is how can i do eliminate the evap purge selenoid? just disconect from the ecu?
No cel on just no vtec, then i put the q31 transistor work perfect but a fw seconds and burn again just quickened hard and burn please help
The answer to you issue has been made: https://honda-tech.com/forums/forced-induction-16/q31-fried-h22-turbo-2973291/
The answer to you issue has been made: https://honda-tech.com/forums/showthread.php?t=2973291
Did you make sure you plugged it into the correct engine harness plug this time?
Is your check engine light on?
Have you checked your codes?
dude no check engine , no codes .. and wiring is perfect all time works perfect but some day q31 fried and no kick vtec
