DC5 2nd to 3rd gear grinding?
Old Aug 29, 2011 | 05:47 PM
aymforyou's Avatar
Icon2 DC5 2nd to 3rd gear grinding?
when i am in cold weather switching from 2nd to 3rd sometime grind on mii is this common ?
Old Aug 29, 2011 | 07:07 PM
doood's Avatar
been there done that
Default Re: DC5 2nd to 3rd gear grinding?
yes. 1st to 2nd is also common.
Old Aug 29, 2011 | 08:04 PM
NEO_FOLLOWER2's Avatar
yep...only thing you can do is
  1. change tranny oil
  2. check the shifter bushings
  3. check the shifter cable bushings
  4. check the shifter cables
tranny oil got rid of 3rd gear grind for me(on my ep3)
and i think sometime my 2nd gear grind is due to my shifter cable bushings..
we will see once i install my bcss i will check the shifter cable and cable bushings for wear and tear and looseness
Old Aug 29, 2011 | 08:29 PM
doood's Avatar
most of the time they synchro's are bad. might as well do a full rebuild.
i replaced my fluid with honda mtf last week and it definitely made an improvement. but it's really just a bandaid fix.
Old Aug 29, 2011 | 10:19 PM
b_ron's Avatar
when i replaced my fluid, it minimized the chances of getting 2nd gear grind, and completely got rid of my 5th gear grind.
Old Aug 30, 2011 | 07:11 AM
you had 5th gear grind!
Old Aug 30, 2011 | 10:32 AM
b_ron's Avatar
to the OP, does it still grind after the cars been warmed up in cold weather?
Old Sep 4, 2011 | 07:41 PM
goreslinger's Avatar
clubrsx has a lot of stuff written about this
jdmsuckah
Jul 8, 2012 07:57 PM
mc-integra111
May 10, 2012 11:21 PM
gm3w12
Sep 27, 2006 09:08 PM
6SPD_EK
Sep 11, 2006 05:05 AM
darkstarmeyers
Jan 26, 2006 12:56 PM
