Detailing Auto Detailing and Concours
water spots on windows???
Old Aug 29, 2011 | 05:00 PM
cadwiese's Avatar
Default water spots on windows???
whats the best way/ most effective way of getting rid of them??
thx
Justin
Old Aug 29, 2011 | 05:19 PM
ONeill24's Avatar
Default Re: water spots on windows???
well it depends how etched in they are. For most water spots though windex should be plenty. However some waterspots don't remove easily if you have hard water and they actually need to be polished the same way you would polish paint to remove swirls.http://www.autogeek.net/dia-glasswork-restorer.html If windex doesn't work this product should do the trick but I always like to try the least aggressive method first.
Old Aug 29, 2011 | 07:20 PM
cadwiese's Avatar
ok well ill order some of that and let you know how it goes
Old Aug 31, 2011 | 10:29 PM
builthatch's Avatar
MiG-21 superfan
i use optimum poli-seal and a green cyclo pad on my porter cable polisher if they are topical deposits that won't come off with a quality spray cleaner. i use varying degrees and combos of pads and optimum polish and my porter cable if the spots are more serious.
glass is pretty damn hard so you won't damage it by using a quality polish, pad and the average dual action polisher. just don't heat the window up too much in any particular spot.
depending on the frequency of the washes, i use optimum spray wax on every exterior surface including the windows. it helps prevent spots actually etching in the first place.
Old Sep 1, 2011 | 08:32 PM
cadwiese's Avatar
ok ill be buying some supplies soon and ill let you guys know how it goes
Old Sep 1, 2011 | 10:01 PM
DA JeLLie's Avatar
http://www.spot-x.net/
Works and its $12
Old Sep 4, 2011 | 09:38 AM
captivahach's Avatar
This is one of the best products that ive tryed
http://www.goswac.com/detail.aspx?ID=648
Old Sep 4, 2011 | 02:04 PM
RepD16Y8's Avatar
I use a razorblade and some windex. I also use newspaper as its cheaper than using paper towels.
Old Sep 5, 2011 | 02:33 AM
SynTeg's Avatar
I've had hard water spots and overspray on my window and i've gently used a razor blade to scrape it off. Just do it in one direction at an angle.
Old Sep 12, 2011 | 01:15 AM
RepD16Y8's Avatar
X2^
ejLday
Detailing
Mar 25, 2009 08:54 PM
ITR32
Paint and Body
Jul 10, 2007 09:27 PM
1ntegrat10n
Feb 15, 2007 08:24 PM
SuperTeg95
Jan 24, 2007 09:32 PM
Knightmare69
May 5, 2006 10:40 AM
