eg built gsr/b16 turbo issues. HELP!!
Old Aug 29, 2011 | 07:25 AM
claysno's Avatar
Default eg built gsr/b16 turbo issues. HELP!!
ok so i picked up a nice clean built and boosted eg. runs great but ran into an issue. when driving this car in any gear but most noticed in 3rd. i roll into it the car pulls good. it will hit 16 psi/5100 rpms and car will shut down. not like a fuel cut. bov will open like lifting out of throttle. also with throttle to floor it will cut and rpm tach will drop to 0 until throttle is realeased. once released it will go back up to normal rpm you are at? car is running hondata s300 with boost by gear solenoid. but i dont understand this. hooked ecu to my laptop and only cel's car is throwing is IAT code #10 and o2 sensor cause its not plugged in. im so confused. please help
Old Aug 29, 2011 | 08:34 AM
boostedteg909's Avatar
Default Re: eg built gsr/b16 turbo issues. HELP!!
does vtec crossover?? possible distributor issue. ive seen a similiar problem like this nd it ended uo bein one of the sensors in the distributor
Old Sep 2, 2011 | 03:36 PM
claysno's Avatar
it may not be. ill invest in distributor. thanks. all other ideas are open thanks
Old Sep 3, 2011 | 01:57 AM
thats the only thing i can think of that would explain wat ur describin. sounds like as soon as vtec should crossover, all ur timing gets pulled nd ur losing rpm signal. u could try swapin dizzys wit a friend jus to check
Old Sep 12, 2011 | 02:26 PM
claysno's Avatar
ttt. bump
viperjng
28
Aug 18, 2011 07:16 PM
Ken99287
Aug 11, 2011 07:13 PM
fhukingviet
14
Jan 28, 2009 12:36 PM
Woogie Ctr
Apr 11, 2006 03:08 PM
