1997 EK Hatch Speedo problems
Old Aug 29, 2011 | 05:15 AM
Superide's Avatar
Default 1997 EK Hatch Speedo problems
Last night my speedo started bouncing all over the place and this morning will not even work. Any ideas on what it might be?
Old Aug 29, 2011 | 05:57 AM
Former User's Avatar
Default Re: 1997 EK Hatch Speedo problems
Any CEL codes? Also check whether 7.5A dash fuse 15 is blown.
Old Aug 29, 2011 | 05:59 AM
Superide's Avatar
No CELs yet ill check the fuse when I go out to the car.
Old Aug 29, 2011 | 06:01 AM
Does the CEL work? Are checking for codes with a code reader?
Old Aug 29, 2011 | 06:04 AM
Superide's Avatar
no i can go get it scanned, but I have seen the check eng light come on before.
Old Aug 29, 2011 | 06:13 AM
If you turn the key from off to ON(II), does the charge light (battery symbol) remain on steady and does the CEL turn on and then off after 2 seconds?
Old Aug 29, 2011 | 08:50 AM
EMUflix's Avatar
might have cracked solder joints on the back of ur gauges (circuit board)
Old Aug 29, 2011 | 09:28 AM
DSMAddicted's Avatar
That was going to be my suggestion.
I was waiting for OP to reply to Ron's question, but that's a strong possibility (cracked solder joints).
Old Aug 29, 2011 | 10:57 AM
DOHCED8's Avatar
sorry to thread jack but im kindof having the same problem. though mine is like 10mph off n sometimes it seems like the needle moves about a 1/16 of an inch back n forth sometimes
Old Aug 29, 2011 | 10:59 AM
grumblemarc's Avatar
The Grumpiest
If you're having the same issues then try following the advice that's already been given.
Old Aug 30, 2011 | 05:39 AM
Superide's Avatar
I just tested this this morning and the battery light comes on but no CEL. Also while I was in there I noticed a yellow 2 prong plug hanging under the dash. What could that be?
Old Aug 30, 2011 | 11:06 AM
virgineg6's Avatar
Sounds like the srs connector but im thinking 92-92 civics so it might not be. Could be just a bad speedo.
Old Aug 30, 2011 | 11:43 AM
Are you saying the CEL never turns on?
Old Aug 30, 2011 | 11:58 AM
Superide's Avatar
yup the light does not come on.
Old Aug 30, 2011 | 12:04 PM
That's not good. Check whether the bulb has been removed or is burned out.
Old Aug 30, 2011 | 12:10 PM
Superide's Avatar
great i guess ill be pulling out the cluster tonight
Old Aug 30, 2011 | 12:42 PM
Superide's Avatar
is there a way that he could have pulled a fuse or anything else cause it does not look like he too the dash apart?
Old Aug 30, 2011 | 12:43 PM
First check the CEL bulb.
Old Aug 30, 2011 | 12:45 PM
Superide's Avatar
will do thanks!
rossthab022
16
Mar 22, 2012 10:11 AM
mixwell
May 8, 2009 12:14 AM
Bulli Kid
Jun 5, 2008 02:13 AM
zcrx2006
Feb 20, 2007 04:48 PM
asianspeed
Nov 19, 2002 09:20 PM
