Iratic idle and bad mpg
Old Aug 28, 2011 | 06:31 PM
UsDm_Junky's Avatar
Default Iratic idle and bad mpg
Hey all, just picked up a 93 del sol s with a jdm d16a swap in it. It has a really weird idle sometimes it will fluctuate up and down up and down and when its not doing that it sits at about 1,500 rpm's. I have been getting terrible gas mileage aswell not sure what I should be looking at first here and or what the problem could possibly be. I know the car was turbo'd before I got it and it even has a fpr installed (not sure if that might be part of the problem).. any help is much apreciated.
Old Aug 28, 2011 | 07:42 PM
ArithMEHtik's Avatar
Default Re: Iratic idle and bad mpg
Clean your IACV and check all vacuum lines? Should help your idle I don't know about you MPG's though.
Old Aug 28, 2011 | 07:45 PM
Townson's Avatar
check plugs and wires.
Old Aug 28, 2011 | 08:31 PM
Former User's Avatar
Any CEL codes? Have you cleaned and adjusted the FITV?
Old Aug 30, 2011 | 05:41 AM
UsDm_Junky's Avatar
No cel codes and I still have to play with the IACV and FITV,are there any writeups on what Ill be looking for/fixing while I'm in there? I also picked up new oem ngk plugs and some ngk wires I will be installing as soon as they arrive.
Dragon760
Mar 13, 2014 04:15 PM
MilanoRedDashR
Honda S2000
May 17, 2013 06:58 PM
JDMFreakz
12
Jul 11, 2012 10:54 AM
sick_dc2
Jul 8, 2008 12:02 PM
ArchAngel Sabastian
Sep 11, 2002 09:29 PM
