cannot get 1000cc to idle smooth ? ive searched
i have a built d16z6 my buddy let me borrow his precision 1000cc injectors to see if i can get it to idle b4 i buy them.
y8 intake manifold- no iacv
dual cam throttle body
and s300...used to have rc440 and idled perfect
i tried makin it idle at about 1000 it is very lean and i cant do anything to make it rich i crank the fuel way up and it doesnt get rich and now it stalls sometimes. it would idle and bounce from 750 to 900 about but very lean and sounded like it had a cam what should i do? thankk in advance very much
Make sure your injector offsets are setup for the injectors.
Make sure you are running a resistor box as precision 1000cc injectors are low impedance.
Set it to openloop, then go to the Overall Fuel Trim under Parameter tab... I set it to 25% going from stock 240cc to 550cc, so i guess for 1000cc injector, you could try setting that to ~40% +/- 5%.
It was idling rough when i did the switch, took me 3 days to figure out that was the thing to change. Now it idle smooth like stock.
