need help!!! d16z6 in a 90
im having a problem with my car.. i did a swap of a d16z6 into my 90 std hatch... car was running until recently when i run my motor it started stalling while driving.... it cuts out but it you play with the pedal it then can return to running like nothing happened... also at idle now its stalling while running... it will start then you hear it pause and then idle drops and come or cuts totally out... it has new dizzy, plug, wires, tps, new ecu... all grounds are good.. i have no clue whats happening
fuel pressure is good.. new fuel pump... new tps... new dizzy and alternator.. both brand new not rebuilt..... iacv cleaned and tripple checked... swap has been done back in this june... this problem just started in the past week
Sounds like your distributor is going out or you have a bad electrical connection somewhere. If it was timing or compression or vacuum leaks you would see the problem constant and not off and on. And just because parts are new does not mean they are good, new parts go bad all the time.
ill recheck the dizzy.. but have checked all sensors and things compression is good... but i havent yet had the chance to trace wires yet.... but i does sound like a short somewhere...
chargerbandit
May 26, 2018 12:32 PM
ten2doyle102
Jun 24, 2008 05:58 PM
