Tips for installing rear drums plz having trouble~
Old Aug 28, 2011 | 02:14 PM
Honda3133's Avatar
Default Tips for installing rear drums plz having trouble~
So i did front brakes with no trouble, now im having a little bit of trouble with the new drums, passenger side is well done i believe when the car is on stands I can spin the wheel 1 turn, but the other one driver side Is very tight and can only be moved about half and when driving u can hear it grind any tips?
Old Aug 28, 2011 | 02:48 PM
94EG8's Avatar
Seagull Management
Default Re: Tips for installing rear drums plz having trouble~
Back the star wheel off a little, there should be a slight drag when turning the drum when they're adjusted properly.
Old Aug 28, 2011 | 04:57 PM
Honda3133's Avatar
ya ive been trying the star wheel but doesnt seem to change much any ideas?
Old Aug 28, 2011 | 05:20 PM
civicjunkie17's Avatar
You've been trying to adjust the wheel with a brake spoon? I would remove the brake drum and check out the star wheel.
Former User's Avatar
What car?
Sometimes the star wheel adjuster seizes up by brake gunk collecting where the two clevises connect to the adjuster bolt. Pull the clevises and adjuster bolt apart and then clean and grease them.
Old Aug 28, 2011 | 05:42 PM
Honda3133's Avatar
thx ill try it out tomorow
Jriddlez
Jan 29, 2013 06:37 AM
bigJOE671
Jan 10, 2013 08:45 PM
moaterboaink1ng
Suspension & Brakes
Oct 29, 2012 11:42 AM
street_ride14
Sep 3, 2011 08:35 AM
95GGSSRR
Sep 11, 2006 10:39 PM
