CR/bore difference on tuned ecu??
Old Aug 28, 2011 | 01:55 PM
peter_b16's Avatar
Default CR/bore difference on tuned ecu??
Hey guys..just got done building my b20v yesterday..it drives pretty Kool..chassis is a 91 crx si..haven't gotten on it yet..how long should i wait to beat on it??
Setup:
B16 Head
Skunk2 valvetrain package
Skunk2 Stg2 cams
Stock ports
Skunk2 IM
B20 Block
Eagle rods
CP 84mm 12.5CR
Oem crankshaft
ACL bearings
RMF rep headers
My ecu is tuned for my previous lsvtec setup wit itr piston..same head..n hytech headers..made 196hp/132tq..how safe will i be running wit this tune??dyno tune is a must but i wanna break it in first and mite need new injectors/tb b4 doin so..also..will i be safe wit 91 octane??
Old Aug 28, 2011 | 04:40 PM
1998GsRIntegra's Avatar
Default Re: CR/bore difference on tuned ecu??
Depends how far the last motor was pushed tuning wise. If the last one was pretty much tuned to the limit in terms of afr's and ignition timing then you will run pretty lean.
Do you have a wideband air fuel gauge? If it were me...I would not be running it at all with out having a wideband on it to see what the afr's were doing.
Looking at it...you have increased the bore by 3mm, and the compression by about 2 points from your old block.
I wouldn't be running it right now with out making sure it isn't going mega lean.
Last edited by 1998GsRIntegra; Aug 30, 2011 at 11:28 AM. Reason: Momentary lack of thought when posting.
Old Aug 29, 2011 | 01:37 AM
peter_b16's Avatar
Looking at it...you have increased the bore by 3mm, the stroke by about 2mm and the compression by about 2 points from your old block.
Yes..it had a pretty good amount of dyno time @PED..i actually don't have an a/f ratio gauge..idk wat it means but i was driving earlier and was coming to a stop..i shifted out of gear to neutral and the engine just shuts off..restarted it and drives cool..happened twice..
Old Aug 29, 2011 | 09:32 PM
juba_x's Avatar
dont b20 and ls b18 have the same stroke just different bores. you are most likely running really lean. its just like my motor but mine is stock just with 13.1:1 cr stock bored tho
Old Aug 30, 2011 | 11:27 AM
Whoops your right. Momentary brain fart for me. Lol
ej1_civic
Dec 31, 2012 09:18 AM
d0odle
Jul 26, 2008 11:33 PM
cltitus
Dec 21, 2006 02:17 PM
99black_em1
Jul 25, 2006 08:42 PM
JDM_GSR_131
Sep 19, 2002 05:37 PM
