Radiator Fan Inconsistently Turns On
Old Aug 28, 2011 | 10:51 AM
Hot Car's Avatar
Default Radiator Fan Inconsistently Turns On
I replaced the switch and sensor for the radiator/cooling system. We let the car run in the driveway for about twenty minutes in this 100-degree weather and the radiator fan would turn on at the appropriate times. On the way home, I stopped at a light for about a minute and there wasn't a problem. At the second light, the temp started climbing. I pulled into a parking lot, popped the hood and found that the fan was NOT running.
I turned the car off, put the key in the ACC position and the fan came on and stayed on until the temp dropped to tolerable levels. When I got home, I sat in the driveway and the temp rose. When it got really high, the fan came on for 20 seconds and then shut off without doing much to cool the engine. I shut the car off, put it in ACC and it did the same thing that it did earlier: stayed on until the engine was within acceptable levels.
It almost sounds like a programming issue. Any ideas?
Old Aug 28, 2011 | 12:16 PM
Former User's Avatar
Default Re: Radiator Fan Inconsistently Turns On
Bleed the cooling system. What car/engine?
Old Aug 28, 2011 | 12:29 PM
Hot Car's Avatar
2000 Civic LX.
How would bleeding the cooling system fix the fan's lack of activation?
Old Aug 28, 2011 | 01:06 PM
Originally Posted by Hot Car
2000 Civic LX.
It's something simple to try first. The ECT switch on the thermostat housing contacts coolant and measures its temperature. If an air bubble is trapped in the cooling system, it can prevent the ECT switch from reading coolant temperature.
Bleeding the cooling system may take 20-30 minutes.
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push/turn the dash heater lever/**** to MAX heat. Fan need not be on.
3) Follow the directions in the diagram below
wildbill_52280
13
Jun 26, 2017 04:37 AM
spidermancivic
May 5, 2009 09:07 PM
biker9075
May 31, 2008 03:35 PM
mike93eh
Mar 26, 2005 03:04 PM
rickytz7111
Feb 25, 2004 06:30 AM
