Changing out an oil pump...is it necessary?
Old Oct 3, 2002 | 06:29 PM
TheSwift1's Avatar
Default Changing out an oil pump...is it necessary?
I'm building a B18C motor that has about 75,000 miles on it...the oil pump looks ok, but i was wondering if it's necesary to replace it for a new one? how do i tell if it needs replacing andhow many miles are they good for?
Old Oct 3, 2002 | 06:48 PM
IN VTEC's Avatar
Default Re: Changing out an oil pump...is it necessary? (TheSwift1)
Got some deja vu going here. Same engine and mileage as me.
I chose not to replace the oil pump or even overhaul it.
I checked for freeplay, leakage, and smooth rotation. Everything checked out OK, and I simply bolted it back on. I thought about using a Toda oil pump gear, but at $300, that's way outta budget and I could buy three or four ITR/GS-R oil pumps for that price.
Old Feb 26, 2003 | 05:56 AM
Fuster_Cluck's Avatar
Default Re: Changing out an oil pump...is it necessary? (IN VTEC)
I'm looking to do some maintenance on my 98 GSR motor before dropping it in the Eg. Only has 53k on it, so I am thinking about skipping the oil / water pump.
Are they really hard to change when the motor is in the car vs. the motor on an engine stand?
How often should you change the water / oil pumps?
Old Feb 26, 2003 | 07:10 AM
IN VTEC's Avatar
Default Re: Changing out an oil pump...is it necessary? (Hybrid93Hatch)
The water pump is a piece of cake, but the oil pump requires you to drop the exhaust manifold and oil pan....not to mention the mess that it makes.
Change it out while you can.
somick
Aug 15, 2017 08:14 AM
5.56
Dec 28, 2008 05:00 PM
garagespecial
Apr 26, 2003 01:16 AM
pinota
Jul 16, 2002 06:47 AM
