Oil dripping from D16z6 tranny
Old Aug 27, 2011 | 08:08 AM
hmonkey86's Avatar
Post Oil dripping from D16z6 tranny
Do you know why D16z6 tranny has a lot of oil droping from it????
Old Aug 27, 2011 | 08:44 AM
grumblemarc's Avatar
The Grumpiest
Default Re: D16z6 Vtec
Leak.
Old Aug 27, 2011 | 09:26 AM
Former User's Avatar
Do you mean tranny? Is fluid leaking from the differential where the axles insert? Or from the weep hole between the tranny and engine?
Old Aug 28, 2011 | 11:51 PM
hmonkey86's Avatar
yes, it mean tranny. my badly. it was between the tranny and engine. i just looking it. i am not sure why it is oil droping. is that true if i have to get tranny out and put new gasket put on between engine and tranny?? let me know. thank you for your help
Old Aug 29, 2011 | 03:14 AM
The Grumpiest
Gasket? You probably need to replace the seals.
Old Aug 29, 2011 | 05:14 AM
apexi_rsx's Avatar
between the tranny and motor is a cheap 8 dollar rear main seal gasket but it takes hrs to replace it. it's behind the flywheel and the transmission needs removed... goodluck. if you don't replace it it will go through quarts of oil a day.
Old Aug 29, 2011 | 05:42 AM
BauleyCivic's Avatar
Risky Business
One of two seals. Rear main seal (on block, means engine is leaking oil), or input shaft seal (in transmission, means transmission is leaking fluid).
Transmission will have to be dropped to replace either.
Old Aug 29, 2011 | 05:47 AM
Default Re: Oil dripping from D16z6 tranny
First figure out whether the oil is leaking from the transmission or engine. Look for a possible source higher up on the engine (VTEC, distributor, valve cover, oil pan) or from the axle seals.
Old Aug 29, 2011 | 06:41 AM
strategy400's Avatar
^That, particularly the distributor o-ring, valve cover gasket and VTEC solenoid. The oil will run all the way down to the bottom.
Otherwise probably the rear main seal, but check the easier seals first.
Clean your engine with degreaser so you can pinpoint where the oil is coming from.
Blazinmiller
Aug 31, 2010 08:14 PM
kaiba
Apr 7, 2007 09:13 AM
petty$rep
18
Oct 12, 2006 07:53 AM
Shotman
Jan 15, 2005 03:50 PM
