ECU question
Old Oct 3, 2002 | 06:01 PM
twitchm80's Avatar
Default ECU question
Swaping a 2000 LS into a 95 civic dx,
1st can i use my stock ecu to see if it runs
2nd What ecu should i get? P72?
Thanks
Old Oct 4, 2002 | 03:05 AM
enhancedCL9's Avatar
Default Re: ECU question (twitchm80)
Yeah you can use your stock one. But try to get a obd0 89 integra It should plug right in... But whatever you do don't buy a newer ECU cause there's aLot of rewiring So there's no point!
Old Oct 4, 2002 | 03:07 AM
kenji's Avatar
25 Year Member
Default Re: ECU question (thizguy)
Based on the fact that he is dropping a 2000 LS motor into a '92-'95 Civic I would say that the ECU intended to run his swap would be a '94-'95 Integra LS ECU (P75/P74).
Your DX (P06) ECU will work just fine. But, an LS ECU would work best.
-kenji
Old Oct 4, 2002 | 03:09 AM
oh i'm my bad, i mean obd1 90-93 integra ecu/pLugs right in!!!... For a second their i thought you were talking about putting it into crx!!! hahah But you can still use your stock ECU it will Also work, But i would rec. getting the Integra one...
ObeyDB8
Apr 4, 2011 09:16 AM
stickybandit6969
Mar 22, 2007 04:51 PM
4DRmafia
Aug 17, 2004 05:46 PM
turbohf
Oct 14, 2003 06:41 AM
(teh)H2OUUP2
Oct 3, 2002 09:17 AM
