HP Problem with m H22a in my CB7
Old Aug 26, 2011 | 04:56 PM
Joh22n's Avatar
Icon2 HP Problem with m H22a in my CB7
Hello, I recently became in love with my car after I got this h22 swapped
Into my cb7. I'm new to all these car stuff so I don't even know anything.. But I have this problem when I got my car Dyno tuned. Now this is a jdm h22a, so once I got my Dyno results I was completely depressed. My results were 126 hp and 131 torque. This is a stock h22a with OEM headers
And my stock accord's exhaust. The person who Dyno tuned my car said that if I just got some bigger headers and a 2.5 exhaust pipe not cranked, my car will push out atleast over 180hp... I am having doubts... Can anyone tell me if buying after market headers
And exhaust
Will really increase my hp that much?
Old Aug 26, 2011 | 06:16 PM
bdmlilburn's Avatar
Default Re: HP Problem with m H22a in my CB7
when you got the engine swapped over did you upgrade the intake and exhaust or is that all stock accord parts also. which ecu are you using
Old Aug 26, 2011 | 06:23 PM
Mufasa's Avatar
King of Lions
Any CEL's?
Old Aug 27, 2011 | 02:55 AM
Joh22n's Avatar
well i have a Generic intake, and the exhaust is all stock from the accord. and i have a tuned p28 now...
Joh22n's Avatar
Originally Posted by Mufasa
Any CEL's?
no, there's no CEL.
Old Aug 27, 2011 | 04:17 AM
accordmatt's Avatar
The stock exhuast is reatricting u somewhat but a exhuast is not gonna prevent u from 50 extra hp. I would look into removing valve cover checkin valve lash, tune up I would research the swap and double check the work. Something is not right to be putting out those #s
Old Aug 27, 2011 | 08:11 AM
nus_dogg's Avatar
Is your P28 chipped though? Just curious.
Also, do a compression check.
Old Aug 27, 2011 | 08:36 AM
bdmlilburn's Avatar
the stock exhaust as definitely holding you back a little. either the motor needs a tune up or adjustment or is improperly tuned.
if your running a stock h22 why not just invest in the p13
Old Aug 27, 2011 | 09:28 AM
Joh22n's Avatar
My P28 just got tuned from the place i dyno tuned it. and thats the result they gave me.
Old Aug 27, 2011 | 09:37 AM
Joh22n's Avatar
iunno,, the person who did my swap for me recommended the p28,so that's all i have.
Old Aug 27, 2011 | 09:55 AM
Joh22n's Avatar
well, i just talked to my Dyno tuner Bubba from Do it Dyno. and says there's nothing wrong with my engine.. he really believes that what is totally restricting my power is my H22a running with the OEM headers and stock exhausts with cats..
Old Aug 27, 2011 | 10:20 AM
hondarin's Avatar
is VTEC engaging?
Old Aug 27, 2011 | 11:43 AM
nus_dogg's Avatar
So I assume it's chipped. In order for a OBD1 ECU to be able to tune, it has to be chipped. Can't just be a virgin P28 ECU; otherwise, car would run lean and what not.
Old Aug 27, 2011 | 02:32 PM
dglassmyer's Avatar
What intake manifold do you have?
Old Aug 27, 2011 | 02:58 PM
nus_dogg's Avatar
I assume he's got a stock IM on his JDM H22A; since, he just swapped it in.
Old Aug 27, 2011 | 03:58 PM
dglassmyer's Avatar
I would too but with power that far off the curve maybe not.
Old Aug 27, 2011 | 04:21 PM
ilikehonda's Avatar
no way the exhaust is restricting that much power. post up the dyno with air/fuel
Old Aug 27, 2011 | 10:43 PM
Joh22n's Avatar
Originally Posted by hondarin
is VTEC engaging?
Well my vtec is a smooth crossover, and yeah I hear it roar.
Old Aug 27, 2011 | 11:30 PM
holmesnmanny's Avatar
Obviously it's not tuned correctly. Save yourself the bs with this place that is ripping you off and get a p13 ecu and call it a day.
Old Jul 23, 2012 | 08:13 PM
cdplaya16's Avatar
And exhaust
I bet your vtec is not engaging
Old Jul 24, 2012 | 11:23 AM
MAD_MIKE's Avatar
MM Gruppe B
Originally Posted by OP
08-26-2011
Originally Posted by newbie
07-23-2012
Trying to get your post count up?
tim.simpson
Mar 7, 2011 08:04 PM
adamez
Jun 28, 2008 12:26 PM
ESP-net
14
Nov 12, 2006 10:22 AM
enigma94
Jan 14, 2005 03:12 PM
specialedition
Aug 10, 2004 09:59 PM
