obd1 ecu wiring
Old Aug 26, 2011 | 12:59 PM
civic-steve-94's Avatar
Default obd1 ecu wiring
hello once again honda peeps alright i was searching for a dash harness for like 3 months and now i have found one and its a non vtec one because apparently the place i ordered it from doesnt know the difference between the two and they dont actually have a vtec but anyway i have been looking at a pin out diagram to wire in vtec
http://www.ff-squad.com/technet/wiring.obd1.htm
and it says that connector A slot 21 and 22 are for the ignition control module i need to know if both of those are used because mine only has a wire in slot 21
car-1994 civic dx coupe
engine-obd1 b16a
ecu-chipped p28
Old Aug 26, 2011 | 04:07 PM
Default Re: obd1 ecu wiring
bump anyone know
Old Aug 26, 2011 | 07:27 PM
bump for someone that knows about wiring
Old Aug 27, 2011 | 12:52 PM
ok really 142 views and no replies does no one know about this or did i just ask a retarded question
this is kinda vital i need to know if i need to put a new wire in before installing the whole harness
Old Aug 29, 2011 | 12:16 AM
wow no one
Old Aug 29, 2011 | 07:47 AM
CivicSpoon's Avatar
Shouldn't matter. Both A21 & A22 connect to each other along the way. If you have issues starting the car, then just add a pin into the A22 slot and splice the wire (soldering it) to the existing A21 wire.
Old Aug 29, 2011 | 09:59 AM
Relic1's Avatar
on a P28, the two points in the ECU are jumpered together, it shouldn't matter at all.
also the only difference between VTEC and non-VTEC harnesses is the VTEC related wires. It's plug-and-play between the two as far as starting the car.
If you're having start problems it's something else.
Old Aug 29, 2011 | 01:27 PM
alright thanks guys ill update when harness is in the car and motor is installed
Old Aug 29, 2011 | 01:35 PM
Blacknight117's Avatar
I hate to sound like an *** but, it`s kinda of a 'retarted' question because it has been asked before. Either Google it, or better yet, search the forum. Use the 'Advanced Search' option. Just my 2-cents.
Old Aug 29, 2011 | 04:47 PM
see now that wasnt to hard was it and the only time i start threads is when i cant figure it out or research turns up either bullshit or nothing thats why i joined honda-tech because i live in the middle of nowhere and run it to alot of quick fix things on my poor civic
slow_cx
Aug 22, 2007 11:11 AM
93(Civic)EG6
Aug 4, 2007 06:10 PM
free99
Jun 21, 2007 07:45 AM
junior40er
May 10, 2006 06:17 AM
Baggy Spandex
11
Jul 27, 2003 08:37 PM
