f22b1 vtec issue
ok i have a 94 accord with a f22b1, well vtec pops at about 2400rpm's and i cant seem to figure it out i put a new vtec solenoid on it and nothing im running a stock p12 and i thought that might be effed up so i bought another stock p12 and put it in and nothing and i cant seem to figure out what the problem could be
please help
please help
on my old f22b1 you couldnt really even feel the vtec. nothing like the kick from a dohc vtec. also i dont think on a stock car vtec kicks in that early. i though it was more around 4500-5500
well what im trying to say is that im positive that it engages at 2400 because when i unplug the solenoid it has no power what so ever all the way to redline but when it is pluged in it has power all the way from 2400 to redline i know it sounds weird but i think something is wrong in my wiring somewhere
Thats how you test if VTEC is working or not. If it runs strong with it plugged in then laggs when disconnect it, the whole circuit and solenoid is in working condition. I don't get why you're running a P12 ECU in a '94 Accord EX???? It should be POA if the car's a 5spd.
Now I am going to quote the factory service manual, from the section "F22B1 engine :construction and function: VTEC - Control system", page 5-7.
Valve timing change conditions:
Engine speed between 2300-3200 RPM (depending on manifold pressure)
Vehicle speed greater than 6.2 MPH
Engine Coolant temperature 50*F or higher
Engine Load (as determined by manifold negative pressure)
It is supposed to engage at 2400
Everybody who says they feel it at 4400 is full of it, thats roughly the peak of the F22s torque curve.
Holmesmanny - just.... no. Not even remotely close to how Vtec works, it's either on or off and there is no such mechanism called a "secondary" at any RPM. It just turns on, bam at a certain RPM and stays on until the motor slows down or you back off the throttle.
Half of the ppl thinks VTEC pop as hard as a DOHC VTEC engine, but it's not. I can't even barely feel mine even when I installed my Bisi Level 2 VTEC cam in. Actually, I can't even feel it.
These F22B1 are made for Fuel Economy; not for Performance like a DOHC VTEC. People needs to understand that.
Vtec pops in about 4200 rpms I feel it just fine since I went straight pipe.. I could really feel the diffrents of the kick its not a big kick like a dual but u could feel it.
civickid03
Mar 25, 2004 11:00 AM
