airbox for a type R swap
Old Aug 25, 2011 | 05:03 PM
grnaccord's Avatar
Default airbox for a type R swap
I have a 98 civic with a typeR swap and I want to use a factory air box with a aluminum pipe so which airbox do use that will bolt to the factory location. I would think a Gsr, Si, or type R.
Old Aug 25, 2011 | 06:21 PM
Linked's Avatar
Default Re: airbox for a type R swap
this is a bit confusing to picture, if you want an air box than will bolt like factory then you get the air box that came with your car, and not from a gsr integra, and theres most likely no difference between the type r, si, or normal ex air box
and you might as well keep the stock air pipe, if you want an aluminum one, just get an aftermarket filter as well
Old Aug 25, 2011 | 08:09 PM
94EG8's Avatar
Seagull Management
'99 - '00 Si airbox and intake arm will be a perfect fit.
chiboy002
15
Feb 11, 2010 01:30 PM
Teglessb18
11
Jun 12, 2008 07:31 PM
farid
Oct 6, 2005 08:13 PM
Raiyo
Mar 26, 2003 11:36 AM
BoroDB8
Nov 18, 2001 06:16 PM
