3G Integra gauge cluster into 5G Civic
Old Oct 3, 2002 | 05:20 PM
eric.'s Avatar
25 Year Member
Default 3G Integra gauge cluster into 5G Civic
I've checked the search engine and cannot find the info I am looking for. I'm trying to acquire the instrument cluster wiring diagram for the '94 and up Integras. I am going to attempt to do a gauge cluster swap. Your assistance is much appreciated.
Old Oct 3, 2002 | 10:36 PM
TurboBumblBee's Avatar
Default Re: 3G Integra gauge cluster into 5G Civic (Transition)
here for the 100th time atleast.. i know ive posted this many times before.. im gonna put it up on a site soon so everyone can reference.. ive done it to my civic and helped probably 10 people do it as well.. good luck
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
match the wire colors and solder and tape the connnections.. make a custom housing for the dash as the cluster doesnt fit perfect can it can be made to look nice. good luck
Old Oct 16, 2002 | 05:59 PM
Pssst!'s Avatar
Default Re: 3G Integra gauge cluster into 5G Civic (95CivicEX)
So the actual mounting of the GSR Cluster Into a 5th gen. Civic involves using strips of metal just like the 6th gen.?
Old Oct 16, 2002 | 08:20 PM
93hybrid's Avatar
Default Re: 3G Integra gauge cluster into 5G Civic (mood)
I did this swap too thanks to 95civic he was a great help. oh and dont forget to check your fuses after the swap i dont remember how many i blew.
Old Oct 16, 2002 | 09:06 PM
EVIL TYPE R's Avatar
Default Re: 3G Integra gauge cluster into 5G Civic (civicrguy)
hehe gotta love it ~ check the pic's in my sig
Old Oct 16, 2002 | 09:21 PM
Default Re: 3G Integra gauge cluster into 5G Civic (EVIL TYPE R)
your dash swap is very nice.. come out great.. i will do that one day to my hatch, i cant stand how people cut the civic door panel when they can heat it up and make it look soo much more clean like yours.. how much did you get the dash and everythign for? ive been lookin for it latetly.. does your heater, a/c and everything else work correclty??
Old Oct 17, 2002 | 04:30 PM
<U></U>
<U></U>
How much did it cost? All the parts were from my salvalaged R...Yes everthing works too!
lsismore
Jan 13, 2006 01:14 AM
9sihatch3
Sep 22, 2005 08:18 PM
wacllp
Feb 27, 2003 09:06 AM
The G2 Racer
Oct 18, 2002 02:38 PM
DB8
Jun 10, 2002 07:53 PM
