Screw that holds rotor button on
Old Aug 25, 2011 | 09:27 AM
Rowdy Rod's Avatar
Default Screw that holds rotor button on
What was Honda thinking when they put that damned philips head screw on the distributor shaft(4cyl) to hold the rotor button on? HOW do you get that out? I even tried an impact screwdriver with no luck.
Old Aug 25, 2011 | 09:43 AM
361 accord's Avatar
Default Re: Screw that holds rotor button on
doesnt it have a built-in 8mm head on it?
spray some PB blaster on a qtip and slather it
Old Aug 25, 2011 | 01:00 PM
holmesnmanny's Avatar
What I wound up having to do one time is to remove the distributor, remove the pieces surrounding the screw and used a pair of vice grips to grab it and turn it about an eighth or a turn each time and then remove the vice grips, put it back on the screw and turn it again, until I can manually take it off.
aTrOcIoUs420
Mar 16, 2010 08:02 PM
zairas
Oct 19, 2009 03:08 PM
rhino87
May 19, 2008 06:04 PM
mzahidi
May 2, 2007 10:18 AM
boosted k20
Jan 7, 2005 10:01 PM
