Will acura rsx seats bolt up in my del sol?
Old Aug 25, 2011 | 08:43 AM
crebert1's Avatar
Default Will acura rsx seats bolt up in my del sol?
I bought some of the cheap "racing seats" off ebay (mistake i know). and now i'm wanting to put some rsx seats in my del sol. does anyone know if they will mount up or will i have to make them fit?
Old Aug 25, 2011 | 08:53 AM
Wrona's Avatar
Default Re: Will acura rsx seats bolt up in my del sol?
you need custom rails
Old Aug 25, 2011 | 09:14 AM
Red_Army's Avatar
s2k seats ftw.
Old Aug 25, 2011 | 09:32 PM
crebert1's Avatar
ok preciate it. i think ill go with the s2k seats.
Old Aug 25, 2011 | 09:49 PM
98civdx's Avatar
Master Detailer
You can get away with plates that bolt/weld to the rail, and then bolt to the OE spot.
I have never seen custom rails for this.
but if you have the tools for metal work, it shoudn't be that difficult for you.
Old Aug 26, 2011 | 07:41 AM
Red_Army's Avatar
s2k's won't bolt right in either. i just like the look of them in del sols.
Old Aug 26, 2011 | 08:16 AM
Libertariat's Avatar
Ek Forever y0!
s2k's are the most easily transplantable seat. You can just swap the seat pan with your 92-00 civic seat pan and the OEM rails bolt right on. I believe RSX seats the seat pan is welded, so you would need to modify the rails to bolt in, or make custom rails.
Old Aug 26, 2011 | 09:38 AM
crebert1's Avatar
ok sounds good. im not the best at metal work but i got someone that could do it. and yea they do look good in del sols. ill probably just get some off ebay. thanks guys.
Old Aug 26, 2011 | 11:50 AM
Wrona's Avatar
what do S2k seats have to do with anything your contribution to this thread is really worthless
Old Aug 26, 2011 | 12:11 PM
grannys65's Avatar
When i was looking for seat swaps my first option were the S2K seats but i never found a set that was worthy, I was just gonna wait till i ran into a nice set then i came upon mint condition 06 RSK seats, i picked them up and then began working on installing them, after doing some pondering about how to install these i came to the conclusion to chop off the brackets off the original del sol seats then weld them onto the RSK seats, the final result......
IMO the RSX seats are way more comfy than the S2K seats.
Old Aug 30, 2011 | 08:35 AM
crebert1's Avatar
thanks alot man. thats a good idea. those look real good.
Old Aug 30, 2011 | 08:57 AM
crebert1's Avatar
you know where i can find the bolts that hold the seat bracket down to the floor? i have searched ebay and found nothing. i lost them in the process of taking my stock del sol seats out.
Old Aug 30, 2011 | 10:54 AM
Josueneta's Avatar
I also got RSX seats on my Del Sol look at my thread it shows how I did it but I just welded the Del Sol rails on to themand that way I just bolted them on but for
Me the rivets were a bitch on the RSX seats I ended up using an electric saw t
vptran1
May 4, 2011 05:52 AM
grannys65
Mar 4, 2011 11:24 AM
zachattack54
Dec 18, 2007 04:53 PM
bjfisher
26
Mar 9, 2006 05:20 PM
harwood39
10
Dec 14, 2004 12:27 AM
