89 civic dash lights?
Old Aug 24, 2011 | 08:06 PM
JDM C.A.R's Avatar
Default 89 civic dash lights?
so i been having a problem with my car turning on when ever it wants to. i changed the main relay and going to change fuel pump this weekend. last night i drove the car turned on perfect but while driving i notice that everytime i let the gas go the dash lights and clock would dim down like if it was loosing power and once i got in gear and drove they got really bright. i dont know if this may be one of my problems why my car turns on when ever. what do you guys think? why is it doing that?
Old Aug 24, 2011 | 08:40 PM
demonicivis1320's Avatar
Default Re: 89 civic dash lights?
Your lights are dimming cause ur taking your foot off the gas aka taking the load off the motor cked your grounds under the hood and get ur alternater cked out
Old Aug 24, 2011 | 09:47 PM
ej1b18c1's Avatar
DEF sounds like a bad ground or wiring issue/alt problem. check all ground and make sure no wiring is grounding out etc..
Old Aug 25, 2011 | 02:17 PM
JDM C.A.R's Avatar
ill defenetly check for ground thanks
Old Aug 25, 2011 | 06:27 PM
turbohatchBnuts's Avatar
more then likely its a ground wire with the under dash harness.
Old Aug 26, 2011 | 07:23 PM
JDM C.A.R's Avatar
ill check those spots as well im working on the car tomorrow trying to fix everything i can its going to e my daily driver. im justhoping its not the altenator cause i was driving on the free way and the battery light kept coming and going for a bit then just never came back.
nflore94
Honda Civic (2001 - 2005)
Aug 5, 2016 05:55 AM
h2506
Jan 8, 2011 08:18 AM
fdser
Feb 11, 2010 10:30 AM
d16z6_b_pirate_13
Sep 29, 2007 09:42 PM
jayshonda
Nov 19, 2004 08:17 PM
