my 93 civic hatch with 95 b18b wont start....plz help
Old Aug 24, 2011 | 06:52 PM
cadwiese's Avatar
Default my 93 civic hatch with 95 b18b wont start....plz help
so i have been having problems with my car starting lately. i go to turn the car over and nothing happens, i try i again and agian, and nothing happens. then ill try again and presto it starts. so that was happening for a few day and now today it went to start, turned over a few time and just died i replaced the starter for nothing now and im getting more mad by the minute
car is a 93 civic hatch with a 95 b18b in it
ty
Old Aug 24, 2011 | 06:56 PM
Fliptard's Avatar
Default Re: my car wont start....plz help
Check all your grounds, and clean them all. there are 3 of them, Clean the battery terminals and all that good stuff. Check all your fuses.
Does it roll over... but not start? or just nothing...?
Old Aug 24, 2011 | 06:58 PM
cadwiese's Avatar
now it does nothing and i cleaned all the grounds, checked fuses, replaced all the power and ground cables also
Former User's Avatar
Does the fuel pump prime? Does the CEL remain on steady when the key is in ON(II)?
Old Aug 24, 2011 | 07:00 PM
cadwiese's Avatar
Default Re: my 93 civic hatch with 95 b18b wont start....plz help
fuel pump primes and the cel goes off
Old Aug 24, 2011 | 07:02 PM
Did the rubber stopper at the top of the clutch pedal fall out?
Old Aug 24, 2011 | 07:04 PM
Does the fuel pump run while the key is held in ON(III)?
Can you push start the engine?
Old Aug 24, 2011 | 07:05 PM
cadwiese's Avatar
the fuel pump primes then it stops
Old Aug 24, 2011 | 07:07 PM
Are you saying the fuel pump does NOT run when the key is held in ON(III)/START?
Old Aug 24, 2011 | 07:12 PM
cadwiese's Avatar
the rubber piece looks to be there and i can try and push start it
Old Aug 24, 2011 | 07:14 PM
Old Aug 24, 2011 | 07:15 PM
cadwiese's Avatar
yes the fuel pump runs
Old Aug 24, 2011 | 07:20 PM
If the fuel pump runs continuously when the key is held in ON(III)/START, then the ignition switch and starter switch on the clutch pedal is fine. It also predicts that the engine will push start. Check that.
Do you have a multimeter or test light?
Old Aug 24, 2011 | 07:23 PM
cadwiese's Avatar
no test light
Old Aug 24, 2011 | 07:30 PM
Buy or borrow a multimeter because you need one to pinpoint the problem. Harbor Freight Tools has one for about $4.
Does the car push start?
Old Aug 24, 2011 | 07:35 PM
cadwiese's Avatar
ok push started it and let it run for like 2 min then shut it off and tried to start it......and presto it starts a million times better
Old Aug 24, 2011 | 07:37 PM
This is likely only a temporary fix. Is your battery low on charge?
Old Aug 24, 2011 | 07:38 PM
cadwiese's Avatar
they tested it and said it was at 85% like a week ago
Old Aug 24, 2011 | 07:39 PM
Have both you battery and alternator tested.
Old Aug 24, 2011 | 07:41 PM
cadwiese's Avatar
ok but i bought a new alternator about 6 months
Old Aug 24, 2011 | 07:56 PM
cadwiese's Avatar
well it started up like 10 more times and sounds a lot better when it starts
d_bravo06
Apr 21, 2017 06:00 AM
theEFsarecoming!
10
Aug 20, 2014 09:58 AM
Jmx305
Oct 28, 2013 07:52 AM
ekVtecPower
37
Jun 2, 2006 10:01 PM
hawaiian_ej1
Jan 5, 2005 11:59 AM
