Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Radiator fans stays ON all the time! Why?
Old Aug 24, 2011 | 05:17 PM
bharatparmar's Avatar
Icon2 Radiator fans stays ON all the time! Why?
My radiator fans will not stop running at all. It starts even in the morning when the engine is cold to touch, as soon as I start the car.
Can someone please point me in the right direction and tell me why this is happening and what I should look out for?
Thank you in advance for your feedbacks.
Old Aug 25, 2011 | 04:18 PM
m_shake's Avatar
Default Re: Radiator fans stays ON all the time! Why?
Bad relay maybe?
Old Aug 27, 2011 | 07:04 AM
bee guz's Avatar
If you just bought the car and that was happening from the beginning, I would say the relay or one of the heat sensors failed and it's wired on to cool.
If it just started happening, I would check the relay and the fan switch that grounds the fan to turn them on.
The car will run normally with the fans on, it just might take slightly longer for the car to warm up on a cold morning to get heat to the passengers compartment.
Old Aug 28, 2011 | 12:35 PM
I just got a code reader and scan the computer and got the following codes:
P0118, P2183, P0128 !!! Don't know what these means and don't know where to start... please help. Thank you.
Old Aug 30, 2011 | 08:01 AM
Originally Posted by m_shake
Bad relay maybe?
Hello,
So under the hood, fuse seem to be okay (not blown), and on the bottom of the radiator I find the ECT sensor 2 and I unplug it and the fan stops spinning but I am not sure if the sensor is bad! What to do? Thank you.
Old Aug 30, 2011 | 08:05 AM
Okay, so I find this sensor on the bottom of the radiator, I unplug the connector and the fan stops; now my question is: how do i know that this sensor is bad? What else should I look for or troubleshoot? Thank you.
Old Aug 30, 2011 | 08:07 AM
I am guessing the grounding is okay since the fan is running, otherwise the fan will not turn on, right? Thanks.
Old Sep 3, 2011 | 10:43 PM
pd0019's Avatar
your ECT (engine coolant temperature) sensor is bad...have that replaced
Old Sep 5, 2011 | 06:38 PM
Hi, thx for the reply...
Is this sensor located on the bottom of the radiator or the one on the engine block? Thank you.
Old Sep 5, 2011 | 07:23 PM
pd0019's Avatar
i believe its the one on the bottom of your radiator...not 100% sure though
Old Sep 5, 2011 | 09:16 PM
Ed-D15b3-Vti's Avatar
I thinks Bee Guz has a point, if you just got this car and from the start it your fan turns on, have it check by an electrician for wire troubleshooting. It is possible your electrical wiring is tap up directly to the battery due to the bad or sensor failure of the ECT.
Old Sep 5, 2011 | 09:18 PM
famous323's Avatar
^ this
Old Sep 5, 2011 | 09:19 PM
famous323's Avatar
engine block
Old Sep 6, 2011 | 07:07 AM
ekmaniac101's Avatar
Side note: Stock, what is the default temp set at for when fans are supposed to run?
Old Sep 6, 2011 | 07:11 PM
famous323's Avatar
195 per manual, but when you purchase a thermostat from a place other than the dealer they're 180 degrees.
Old Sep 8, 2011 | 11:07 AM
Thanks. I need to get a more specific temp gauge, without breaking the bank
Old Sep 8, 2011 | 08:37 PM
pd0019's Avatar
engine block
there are two...the top one is sensor 1 and the bottom one is sensor 2. sensor 2 is the one causing the problem, there is a TSB on this, so id start off replacing the one on the radiator and not the block.
Old Sep 15, 2011 | 06:22 AM
HNDA_4SHOOR's Avatar
Bad relay maybe?
this I agree. Seen it plenty of time
Old Sep 16, 2011 | 06:30 AM
Hi Guys, Thank you all for your help. I changed both sensors (engine block and the one on the bottom of the radiator) and the problem has been resolved. I can see the difference in car's performance. It's running much smoother and should see mileage improvement also. Again, thank you very much.
Old Sep 16, 2011 | 06:31 AM
Thank you.
Old Sep 18, 2011 | 02:29 PM
pd0019's Avatar
Old Jan 5, 2017 | 01:31 PM
Halima Khatun's Avatar
Can someone please help me, is the fan ment to stay on? How much does it cost to replace thermostat as someone said that it might need changing. I also took it to Halfords battery and altonor is fine. Engine working fine but some people have noticed the fan is on. Very wary don't know how dangerous this is and the cost.is the fan not Ment to turn on as the engine goes on regardless of how cold it is?
Old Sep 4, 2017 | 12:10 AM
Jorvik's Avatar
I'm also having the same issue on my newly acquired 07 Civic ES but I'm not seeing any fault codes via OBD - is this normal?
Thanks
Mr. M
20
Oct 16, 2013 02:24 AM
roni_xxp
Feb 22, 2009 06:35 PM
jshireaz
Aug 9, 2007 04:47 AM
crxkid24
Sep 22, 2006 12:42 PM
Dave421
Apr 6, 2006 03:32 PM
