B series interchangeability..specifically cooling system
So I've run into an overheating issue. This happened two months ago, a thermostat cured it. I'm sure the whole system could use an overhaul. For all of the components in the system, are they a "universal" b series, or does it break down to specifics (i.e. b16, b18, b20)
I have a high comp b20b.
why not just have it flushed?
im sure the other components are fine.
if you are that worried change the water pump and have it flushed.
or flush it yourself
take thermostat out and bolt the pipe back up, then unhook the top hose and run water through the system backwards
89ED
Jan 27, 2019 10:53 PM
donkiman
Aug 8, 2004 06:41 PM
EK45VTi
Apr 22, 2004 08:16 AM
