Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Help! Trouble getting out of parking
Old Aug 24, 2011 | 09:21 AM
shawnlee250's Avatar
Default Help! Trouble getting out of parking
My sister 03 mdx is having some problem. Yesterday after work her car won't crack. So I assume something small like the battery die. Went there and check the battery and was totally fine. First the car didn't bothered to crank over. The next day we tow to my bro to get it check out.
When the tow guy drop it out, The car was in neutral and it crank fine. Then I shut it off and tried to crank it while it on park. It didn't want to crank over. I then put it back to nuetral and start it up. Then it crank. I tried to put in all gears but having difficult problem with d4 d3 d2 and reverse. It seem stuck and really really tight to get in. I hit the brake and didn't heard the brake switch release, possibly it the sensor for it.
Anyone had problem like this before? Any tip I should check like fuse, brake light, shifter cable? Any tip would be great. Thanks
Old Aug 24, 2011 | 08:27 PM
Default Re: Help! Trouble getting out of parking
Nvm found issue. Delete thread
Samuel Boyd
Mar 18, 2017 01:49 PM
SeanRK
Honda CR-V & Element
Dec 8, 2015 04:12 PM
silez
May 1, 2014 03:55 AM
03ep3sicivic
Jun 28, 2009 08:05 AM
