300whp B20v, Cant Spin 2nd! Hooking or problem?
Alright guys, I apologize if this sounds RICEY, but I recently got my setup done and tuned and was wondering if this was normal.
stockblock b20vtec, 3in DP->cutout, garrett 57trim, 8psi, Tial wastegate
Made 300whp, 219trq on cromepro(no boost by gear ofcourse)
When Im doing a run on (nitto neo gens 205-50-15) on a roll and punch it, itll spin 5500+(not very hard either), but once I go into second, the car just hooks(not a bad thing), but I was just stomped because I've seen/been in/driven cars with less power that RIPs 2nd!
So Conclusion, car will spin 1st, but hooks 2nd+.
I know the clutch ISNT slipping for a fact, so any other reasons as to WHY the car is behaving this way?
you're bitching about not spinning 2nd?? Spinning the wheels doesn't mean you make globs of power.. i'd rather hook in 2nd then spin in 2nd..
If you made good power on the dyno and you still dont feel right, take it to a track and the time slip will reveal your real answers
I ran the nitto neogens as well but on 17's (205-45-17) and would dead hook 375whp in second gear as well (with b16a tranny non lsd) in the summer from a roll as well. But if I snatched second it would spin but if I granny shifted it would hook.
Lets see the dyno sheet. Those are pretty low torque numbers.
Horsepower doesnt mean anything, you want to tune so the torque line holds power till it falls off. The dyno sheet will tell alot.
I have a stock b20, no vtec, super 60 42/48, 2.5" downpipe, blah blah.. and my numbers are 234hp/223t. So the HP number is close to the torque which means every stroke has more power. Get what im saying? with your set up, you might spin 2 revolations to make the same torque as 1 revelation with my set up. Not trying to rag on ya here.. but alot has to do with the set up and mostly the tuner.
Heres my dyno sheet.
Edit: Now realize im only revving to 7.
heres the graph! I thought the torque was 219, but its actually 215!
NOTICE the power/torque increment differences..RED is with new turbo, BLUE is with the old smoking turbo! Same boost(8psi), retuned!
I sort of have boost by gear cos my big *** turbo lol - 1st gear max - 8 psi, 2nd - 14 psi, 3rd and above FULL BOOST - yee ahh!! I rarely get wheel spin and love the element of surprise hehe.
I dont know why that graph looks weird, maybe its just me but according to the graph your making more like 315hp and 280tq. Also you dont see much power below 5k rpms, I think you have a boost leak or a laggy turbo.
TQ and HP are scaled differently on opposite sides of the graph. What cams are you running? I wouldn't count that spike at the end, so it looks like you are putting down around 280-285WHP at your peak.
Youre right! I didn't even think about that. But I figure even with that power, tires will still be squealing.
Dynojet my friend!
Btw, hitting famoso raceway in two weeks! I guess we'll have to see then what kinda numbers I can run.
Where do u guys think it should be? (stock suspension, either 22x8x13slicks, 24x8x13slicks(probably best choice, but well see), or nitto drags 205-50-14)
Full weight and I can SOMEWHAT drive, but idk how well the stock suspension holds up with this kind of setup. Ive seen people run 11s with this setup, but I'll be happy with anything in the 12s, but I feel it might be low 13s
having that much power on stock suspension is something i wouldnt do.. that suspension is designed for a 90hp econo engine..
I woulda upgraded the suspension and bushings as one of the 1st mods done. Especially sway bars!
good luck to ya buddy
