Who have run supertech pistons?
Anyone running the 12.5:1 high compression 84.5mm B20 pistons?
Is is too high of compression with an ITR head (stock)? It's strickly a track car. I'm trying to debate between 11.5 or 12.5:1
im building a 84mm b16a with some. my research didnt bring anything up with the pistons themselves but a few years back people were having issues with their rings smoking some. they supposedly fixed the problem but im using cp rings on mine just in case.
when we went to put the bottom end together wenoticed that the box of cp rings and the supertech rings are exactly the same. and the rings look exactly the same too. the boxes looked identical. if we had mixed up the boxes we wouldnt have been able to figure out which was which. seriously
Several years ago I built a 12.8:1 85mm B20 using these pistons. Still running great, the only thing I didn't like was the piston slap. I set the clearance to the spec sheet which was way too loose.
Everyone loves pics
K20 pistons for a road race motor with experimental cams. Needed more clearance on the exhaust side so a bridgeport mill compliments of Applied flow was done.
