b18c1 toda help please!
Old Aug 23, 2011 | 03:33 PM
lukeb89ef's Avatar
Default b18c1 toda help please!
ok guys, i jumped into a all motor build and im now realizing i may be in to deep!! i have a b18c1, the build hasnt went past the head yet, so i have toda spec c's toda cam gears toda valve springs and am runnng flat faced valves new guides titanium retainers ect. head will be ported polished valvejob all that good stuff..BUT, ive gotten to the point im gettin into the bottom end and uh oh!!! im lost lol, this car is goin to be once maybe twice a month drivin car but we have no tracks close so it will be drove around town some...i understand even tuned its never gona run well in town but what kind of compression should i run? i was wanting to tune on 93 octane seeing as we only have a small airport i could possibly fuel at that would cost a fortune if i had to run anything higher. im not shooting for crazy top end more autox style driving. anyone have a similar setup or kno wich direction i should go on this bottom end? any help appriciated thanks
Old Aug 23, 2011 | 05:27 PM
TheShodan's Avatar
Moderator
Default Re: b18c1 toda help please!
The Toda Spec Bs and Spec C cams need to have at least 11.5:1-12.0:1 compression to work properly. They are fantastic cams to utilize the B18C1 powerband. I currently use these camshafts and though there will be others shortly around to say to get something else, I can honestly say after being in the Honda game for over 14 years, I couldn't have picked a better camshaft for their use (if street and street/road race) purposes.
Here's an example of my build using them. Please focus on pages 5-6. I originally had Jun 3s at first, and switched to something much more reasonable yet still providing a great powerband.
Old Aug 23, 2011 | 05:35 PM
FlewByU352's Avatar
How's the wear with TODA cams though? Could be all talk but I heard they have steep ramp rates that beat the shift out of the rockers and such?
Old Aug 23, 2011 | 06:34 PM
TheShodan's Avatar
Moderator
It's all bullsh!t talk. My brother has a set going on 10 years on the cams with no issues, (same rockers and LMAs). I'm on year 3 myself for my NA car and year 6 with my turbo car.. Its all on how the spring install heights are set for cams doing that. (Brother's car is Type R NA w/ Spec Cs, my Civic has Spec Bs, and my turbo Time Attack car has Spec As).
TODA POWER!!!!!
Brother's DC2-R Toda C
NA Civic (Project NA) Toda B
http://www.youtube.com/watch?v=z1VSvpb8SQo
Toda Spec A DC2-Turbo
http://www.youtube.com/watch?v=tV1RidDku_g
http://www.youtube.com/watch?v=5R5OjeTBRRE&NR=1
Old Aug 23, 2011 | 06:54 PM
lukeb89ef's Avatar
awesome!!! see i was looking at trying to run super high compression like 13:1 or 13:5 for my spec c's but unfortunatly fuel is a issue in my area, but i could tune on 93 octane at 12:1 cr but i didnt kno if that compression would be high enuf for the spec c's, i just want sumthing thats gona be reliable and make some decent power and that deff makes me feel better bout my build thanks
Old Aug 23, 2011 | 07:03 PM
TheShodan's Avatar
Moderator
No problem. You definitely don't need 13.0:1. If anything you'd have to reduce timing as though it were much less. So stay about 11.5:1-12.5:1 and you'll be fine.
Old Aug 23, 2011 | 07:09 PM
Exempt's Avatar
I think you should give your bestest friend which ever DOHC VTEC head u choose not to use and them GSR cams... Just sayin...
Nice builds BTW TheShodan... And awesome info... Thats exactly what we were looking for... First hand experience, not just hear say...
Old Aug 23, 2011 | 08:31 PM
FlewByU352's Avatar
Which one of them do you like best for say a DD/weekend warrior?
Old Aug 24, 2011 | 06:55 AM
TheShodan's Avatar
Moderator
Actually, since none go to a drag strip, they're all weekend warriors at either Gingerman, Beaver or LimeRock, so they all could qualify. None of them are driven "daily" any longer. I have a regular 03 Accord for daily duty. Roads (and subsequent thefts) are too bad here to have those for daily purposes. But I like each car equally for different reasons. The simplest to drive is my brother's DC2-R. Simple, powerful, effective, fun...What more could you ask for?
Old Aug 24, 2011 | 09:46 AM
lukeb89ef's Avatar
to exempt (tiberious harold norman joyce) <- just in case yall wanted is full real name lmao
oh dnt worry buddy we still gota assemble the motor redo a transmission and a ton of suspension work, im sure u will end up with the head and cams since u have shop access :D lmao BUT u have to lsb20 the rex if i give it to ya period no more excuses
Old Aug 24, 2011 | 11:15 AM
koczeka's Avatar
I am runnig C in my PCT piston 1.8
Not baaad cams.
Edit: TODA belt I am using and planning to get a new one after 60k miles.
Old Aug 25, 2011 | 09:34 AM
lukeb89ef's Avatar
did you have to sleeve ur block running these compressions? and also you ever heard if a stroker crank would be good to run with the spec c's?
Old Aug 25, 2011 | 10:38 AM
90efhatch's Avatar
TheShodan what timing belt is the black Integra with the Toda C's run over the years, and how did they wear?
Old Aug 25, 2011 | 11:32 AM
FlewByU352's Avatar
Not baaad cams.
Any dyno graphs or insight on how they perform? A funny concern to have when modifying a motor for more performance is how is the gas mileage?
Old Aug 25, 2011 | 11:45 AM
90efhatch's Avatar
He posted a graph in the dyno thread a while back.
Old Aug 25, 2011 | 04:32 PM
TheShodan's Avatar
Moderator
I only sleeved the block on the Turbo TA Integra from back in 2003. The others are all stock sleeved. sleeving and compression ratio don't have much relevance to one another until you start boring the cylinders
When you mean "stroker" I assume 2.1 and 2.3 litre kits? I have no experience with any positive or negative effects of using those size stroker kits with those camshafts. Most who run Toda are either VERY specific with getting these cams with what they have or are from different countries in which neither "stroker" kits are used nor concerned with.
Old Aug 25, 2011 | 04:33 PM
TheShodan's Avatar
Moderator
Black DC2-R is running a Power Enterprise timing belt. the others are running TODA RACING timing belts. Normal wear to belt, rockers, and LMAs.
Old Aug 25, 2011 | 10:37 PM
koczeka's Avatar
Here we go. 2 IM manifolds compared on the chart.
b18c with PCTs, untouched b16a2 head, RC440s, SMSP B19 header
I am burning 10liters ($2.35 per liter) of 100oct fuel in 100kms. Calculate...
Degreed them to (on the dyno for best overall performance) about 99, 106 instead of the factory 105, 105.
lukeb89ef
May 24, 2011 07:26 PM
G-Stick
K Series
Apr 24, 2010 04:04 AM
omiehomie
Sep 5, 2007 07:38 PM
daNk9
Feb 19, 2004 03:48 PM
Turbo R
Aug 15, 2002 07:36 PM
