sidemarkers wont work!!!?!?
I got a dx civic and i did a mini wire tuck on it and basically did everything right , but for some reason the sidemarkers on my fenders are not working any suggestion?! Anyone know where the relay is at?? thanks for the comment
There is your problem right there... you basically did it right... you should DO it right. Are you talking about a side marker or the parking lamp? You're welcome for the comment.
if they worked before, something is probably not wired right. also, there is an ICU module behind the dash fuse box that controls the corner lights...that module could have gone bad.
REDO all your "basically done" mini tuck and do it "Correctly, and the right way"
First Check the Fuse that is Relevant to that circuit
Second If Fuse is blown Do not replace it
The would most likely be caused by the mini wire tuck causing a Short
Prob the wiring/circuit for exposed/shorted sections.
If above fails
Check fuse
Bulbs
Connections
etc
If above fails
Check fuse
Bulbs
Connections
etc
medwards1126
Jul 6, 2018 04:35 PM
julioboostamante
Nov 4, 2011 03:33 PM
