A6 cam in D15B1
I installed an A6 cam with y7/y8 cam gear in by hatch. It is running pretty good but I did notice a little bogging at low rpms. Also my belt seems very loose. I know it is 1/2 tooth off but it looks like there is more slack in the belt on the left side of the cam (front of the car) and less on the right side (rear of the car). Any suggestions would be great. Thank you
OP - if you have a D15 long block you should be using the same cam gear. You only switch cam gears for when you do "mini-me" swaps...
Hm... I don't think ignition timing will correct for 1/2 tooth off.
Sure, it can help when the spark plug fires, but it can't control when the valves open or close.
I think you would want it the 1/2 tooth off to be advanced making the intake valves open just a tad too early and exhaust valves close a tad too early.
Oh well, let's be exact and do it right, just like vinyl wrapping a car instead of a paint job, am I right "jlk16188"?
14210-PM3-000 - same part number for cam gear for D16A6 and D15B1 and D15B2
D15B1 and D16A6 use same PM3 head.
The OP just needs to use the right cam gear and right belt and tension the sucker properly.
Period.
Period.
The y7/y8 cam gear is different for obvious reasons.
Yes I do read - I'm wondering if you do?
You have that completely backwards... The exhaust side should be tighter than the intake side as they are reverse rotation engines...
o/p loosen your tensioner, line the crank pully mark and the cam gear marks up how you should and reset your belt. then rotate the engine cc till the belt is tight then tighten the tensioner down.
The 88 A6 cam is indexed similar to th USDM D15B1/2/7 engines. The 89-91 A6 cam will either need a Y7 or an AEM adjustable cam gear to compensate for the 1/2 tooth difference.
Here is a link that should answer all of your questions.
http://www.d-series.org/forums/engin...-cam-post.html
BTW: The reason I suggest the AEM cam gear is because nearly all other manufacturers have their D15B/1/2/7 and D16Y7 cam gears improperly marked and indexed. At least this is true for the Bisi and Skunk2 gears.
Ef4doorwagon
13
May 17, 2014 06:09 PM
Nickboxer7
Jul 16, 2007 08:59 PM
rass1313
Mar 14, 2005 11:20 AM
it's not totally necessary, but yes. Also one can run the d15 belt on the d16 in a pinch as the belt itself is only 1 tooth different.
