take a look at this build
Old Aug 23, 2011 | 10:37 AM
maddog42's Avatar
Default take a look at this build
im trading for this motor this weekend... what do yall think?
build consists of b16a2 block bored to 82.00mm by buddy rice
rs machine 8.63cc dome ctr pistons 82mm oversized
b16a2 crank and rods
arp rod bolts
stock windage tray and oil pan
b16 oil pump
b18 waterneck
pr3-4 itr head only 1000k on it
itr cams
skunk2 cam gears adjustable
stock itr dual valve springs
stock valves
crome b16 intake manifold
real itr 98 spec headers
b16 distributor obd1
gs-r transmission with f1 racing lightened flywheel
xtd stage 3 6 puck clutch
yonaka solid motor mounts for eg
uncut wiring harness
stock 240cc injectors
itr fuel rail
p28 ecu
b series axles for eg
eg shift linkage
short shifter with stock ****
stock head bolts
hastings 82mm piston rings
king coted rod and main bearings
12.0 to 1 compression motor
this motor has never been driven
Old Aug 23, 2011 | 11:47 AM
igorka_91's Avatar
Default Re: take a look at this build
not another b16
nice setup.
Old Aug 23, 2011 | 11:52 AM
maddog42's Avatar
lol i only ask cause im trading one of my cars for it and im thinking about taking my GSR out and putting this in so??
Old Aug 23, 2011 | 12:27 PM
90efhatch's Avatar
I wouldn't take out a 1.8l to put in a 1.6l
Old Aug 23, 2011 | 12:28 PM
S1LENT94D00R's Avatar
x2
Old Aug 23, 2011 | 12:45 PM
maddog42's Avatar
yeah i was also thinking of some how combining the two some how and could get good power
Old Aug 23, 2011 | 01:21 PM
igorka_91's Avatar
x3.
I walk my friends b16 swapped eg vx hatch. He has ctr pistons and ctr cams b16 trans.. with in my dc2 with b18c1 81mm usdm itr pistons and gsr cams and gsr trans.
Old Aug 23, 2011 | 01:30 PM
dc4teg's Avatar
I agree.
Old Aug 23, 2011 | 01:55 PM
maddog42's Avatar
so what about combining the parts from my gsr and this build like maybe putting the itr head on my gsr with the ctr pistons
Old Aug 23, 2011 | 02:04 PM
igorka_91's Avatar
that would be like a poor mans ITR setup except with the compression around 13.
Old Aug 23, 2011 | 03:01 PM
93egSLEEPER's Avatar
Stay away from CTR pistons in the GSR. Look at PR3's P30's or JDM ITR slugs for upping the static compression if that is your goal. I know this is a verrrrry hot topic and causes alot of arguements BUT power can be made just as easily with 11.5:1 CR as 13:1 CR....and your saving much needed room for clearance if you decide to run larger cams.
Old Aug 25, 2011 | 12:26 AM
anothersickhatch's Avatar
Originally Posted by igorka_91
x3.
Your friends motor must run like crap. we are talking about the motor, not whether or not he can beat an integra with your mods. what does walk even mean?
Old Aug 25, 2011 | 02:01 AM
igorka_91's Avatar
What mods do i have? mod for mod he had more mods. more CR, bigger cams in a lighter chassie. Shure runs like crap butt takes stock srt4s...mkai.
Old Sep 1, 2011 | 10:53 PM
tpham858's Avatar
igorka 91 likes slang doesn't he. I'm sure "walking" means something like he was so fast that the B16 seemed like he was walking. just a guess. haha no flaming intended
civicmitch
Jun 4, 2009 10:28 PM
b20vtech
22
Apr 3, 2007 04:54 AM
6doorsentra
10
Apr 21, 2006 04:40 AM
VtecKiDD
Dec 13, 2004 07:02 AM
Determined
14
Apr 28, 2004 07:34 PM
