Need bolt torques for installing new idler pulley
Old Aug 22, 2011 | 10:54 PM
the soL that could's Avatar
Icon6 Need bolt torques for installing new idler pulley
mine went out... so i purchased a new OEM (1). however, there are not specs on how to torque this thing. anybody?
Old Aug 22, 2011 | 11:00 PM
pliskin8's Avatar
Default Re: install AC idler pulley
they actually sell the tool to adjust it or you can just go by feel (that's what i did)
Old Aug 23, 2011 | 05:57 AM
Former User's Avatar
Default Re: Need bolt torques for installing new idler pulley
Old Aug 23, 2011 | 07:21 AM
strategy400's Avatar
Good luck getting a torque wrench in there. That is one of the few fasteners I use the two grunts method of tightening.
(You only use one grunt on the oil filter).
Old Aug 23, 2011 | 07:23 AM
Jimster480's Avatar
what torque? I tighten it with a box wrench until its tight.
Old Aug 23, 2011 | 07:35 AM
Originally Posted by RonJ@HT
where the heck did you find this... lol i have the service manual and looked through all 1200 pages.
i plan to remove the AC bracket... unless you folks got a better idea.
Old Aug 23, 2011 | 07:52 AM
Look in the engine removal or timing belt removal sections.
Old Aug 23, 2011 | 08:18 AM
BigMike0147's Avatar
I'm going to put my money on 40 or 43 lb/ft. I've done that job a lot and you set your tension of the belt first by rotating the crank to where the cams move 3 teeth, then torque down the idler to one of those.
Boom. 40 lb/ft I guess. This is a great writeup with pics.
http://www.team-integra.net/forum/bl...nt-g3-teg.html
Oh yeah, this is if you have a B-series. SOHC might be totally different. LOL
Old Aug 23, 2011 | 09:20 AM
^I think you are mixing up timing belt tension and A/C belt tension, though the OP wanted to know how to torque the A/C idler pulley bolts.
I think he's talking about the A/C idler.
Removing the A/C bracket shouldn't be necessary and won't help as far as gaining clearance for torquing. You have to tighten everything after the belt is properly tensioned (so all components have to be in place). It might be easier to assemble all the parts with the idler bracket removed.
Just use a box end wrench for the pulley bolt and a 10mm socket/ratchet w/ long extension(s) for the adjuster bolt.
If you really want to go crazy you can remove everything, torque to spec, mark the brackets and fasteners, disassemble/mount/reassemble and torque 'til the marks line up.
Old Aug 23, 2011 | 09:52 AM
You may be able to access the idler pulley bolts with a torque wrench by raising the engine with a jack under the oil pan. Of course, protect the pan from the jack with a piece of wood.
carlos8
Apr 10, 2015 05:32 PM
Bigbob94
Apr 12, 2010 06:36 PM
bigern1970
Jan 23, 2006 09:54 AM
LeonardDB
Nov 21, 2005 05:28 AM
NaVamous
Apr 14, 2004 09:28 PM
