Max. size of injectors and P28?
as long as it works under 12v and ground controlled, then the ecu can make it work
but the stock ecu cant turn the injector down so any injector bigger than the stock 240s will cause the motor to run rich
getting a tune means crap w/o the means of putting the tune in the ecm. either via a CHIP or a full blown ems.
the s200 uses chips. so in effect it is a chipped ecu.
the p28 can control any injector providing it has the correct resistence through the driver circuit.
dont worry about how big it can, but how big you need. being out of the loop and having crappy rc1200s for the run i ran my car, my s300 with 1200s did ok. idle was tollerable. but with the new crop of injectors and all the updates hondata was coming out with, you shouldnt have an issue.
CaptivaBlue
Apr 9, 2005 03:54 PM
