finally getting a swap. but there are questions i need to ask.
thanks to my new job and my brothers, i now can get a b18c. yeppi
. im planning on going turbo with a kit or a custom one. i might also be running a direct port if my brothers plan on getting it.
now the problem is with the swap and a turbo. will we need to modify the x-memeber. i will also be gettin the z10 and a different radiator. another problem is that i want to keep the gsr tranny and i heard it wont fit into the EF body what can i do with this problem.
and with the OBD0,OBD1,OBD2 which one should i go with? im not even sure what to do with wiring and ecu's and junk like that. mostly i want to know what to do with wiring.
any other helpful hints will help me out alot. as far with the search botton, its been helping me alot too.
. im planning on going turbo with a kit or a custom one. i might also be running a direct port if my brothers plan on getting it. now the problem is with the swap and a turbo. will we need to modify the x-memeber. i will also be gettin the z10 and a different radiator. another problem is that i want to keep the gsr tranny and i heard it wont fit into the EF body what can i do with this problem.
Good choice to turbo....
As far as I know you won't have the modify the x-member. I would recommend going OBD-I. I think you should get a chipped P28 but I could be wrong.
Please tell me if I'm wrong but I'm pretty sure that will work...
helpmycivic
Jun 19, 2009 12:21 AM
