EJ stalled and now won't start
Old Aug 22, 2011 | 01:06 AM
Broke_not_built's Avatar
Default EJ stalled and now won't start
Sup people, new to the site and my first post is a fuel issue.
I was at a stop sign and put it in 1st and the throttle started bogging out, I figured I just ran empty cause I was pretty low and on my way to the gas station. but got fuel in my car went to start it and it started but the idle was crazy and when I pressed the gas it stalled out, and after it never wanted to turn over. I`m sort of stuck I dont know if its the main relay which for some reason isnt in the right spot in my ej and cant seem to find it or if its the fuel pump or tps.
anyone have any ideas?
Old Aug 22, 2011 | 01:13 AM
virgineg6's Avatar
Default Re: fuel problems
If its not turning over its not gonna be your main relay or the fuel pump neither of them have anything to do with turning over. Is the fuel pump priming before you start the car? Should be a buzzing or humming noise when you put the key on II.
Old Aug 22, 2011 | 02:07 AM
Yeah theres a buzzing noise coming from the pump when I turn the ignition on.
Old Aug 22, 2011 | 07:09 AM
virgineg6's Avatar
Default Re: EJ stalled and now won't start
Check all fuses under the dash and in the engine compartment.
Where you located?
Old Aug 22, 2011 | 10:40 AM
Former User's Avatar
What type of problem is this?
--> No-crank (starter doesn't turn engine)
or
--> Crank-but-no-start (starter turns the engine but it won't start)
karrar55
Mar 20, 2011 03:13 PM
Jooleeus
13
Jul 20, 2008 08:46 AM
Marcpb443
Jul 16, 2006 08:59 PM
B18Cej1
12
Nov 8, 2005 05:05 AM
H22CL
Aug 1, 2005 05:43 AM
