Temp gauge sender V. TW sensor
Old Aug 21, 2011 | 07:48 PM
s13hero's Avatar
Default Temp gauge sender V. TW sensor
I am wiring up an aftermarket gauge as my current gauge does not work despite replacing the sender once already, so I replaced it with another water temp gauge, a sunpro one, and put the sender where the factory one was in the block, well it reads high just outside of the warranty. Anyway the new gauge I have is an electric one that reads the temp from the ECU, if this is the case, there is no need to replace any senders correct?
Old Aug 22, 2011 | 07:34 AM
s13hero's Avatar
Default Re: Temp gauge sender V. TW sensor
Rather a long post, but I guess I should be more clear, essentially what I'm asking is,does the ECU read the water temp from the WT sensor, and not the temp gauge sender?
BlackDeuceCoupe
Dec 10, 2002 04:22 AM
erniecars
Jun 14, 2002 11:48 PM
