Transmission & Drivetrain Gearboxes, Differentials, Clutches
Hybrid s20 Tranny
Old Aug 21, 2011 | 06:13 PM
User 12720's Avatar
Default Hybrid s20 Tranny
I have decided I am going to do a hybrid d16 transmission in the upcoming weeks. I already have a s20 transmission so I will be using that. So far this is what I am thinking:
92-95 ex transmission
stock 4.25 Final Drive
1st - 3.25
2nd - 1.9
3rd - 1.565 (from mfactory)
4th - 1.172 (use 3rd from 96-00 dx/lx as 4th)
5th - .702
First has anyone tried this setup? The shift point from 2nd to 3rd is wicked. With 205/45/16 tires and a 7200 rpm redline, 4th gear should end right at 100 mph.
Is the 1.172 3rd gear from a 96-00 a direct fit as a 4th gear into a 92-95 transmission, or is there boring/notching required? Any advice is appreciated.
Old Aug 21, 2011 | 09:33 PM
Bense's Avatar
Default Re: Hybrid s20 Tranny
what does 1-(1.172/1.565) =
Old Aug 22, 2011 | 12:13 AM
Mista Bone's Avatar
D Tranny Guru
that 3-4 shift will suck worse than any HF shift point!
Besides ZC 3-4 wins in this setup, but so does 20" slicks.
Old Aug 22, 2011 | 05:24 AM
User 12720's Avatar
Two of the people I wanted to hear from . Ok I am new to this so I have to ask out of curiosity, why are you asking me what "1 - (1.172/1.565)" equals? I was worried about the 3-4 shift but I entered the data into a theoretical gear ratio calculator, and it didn't SEEM to bad. Shifting at 7200 rpm and landing at around 5400 I think is what it showed. Right now I am used to DX gearing, so that might explain a lot as to why it doesn't seem so bad. However, knowing that you have knowledge in this area I am going to take your advice on the zc 3-4 gears. Can anyone point me in the right direction to a person or place that is selling a used zc transmission or gears.
Old Aug 22, 2011 | 09:17 AM
94EG8's Avatar
Seagull Management
S20 CX/VX 3rd is a lot easier to find than ZC and still works pretty well. Can be flipped and used for 4th with no machining necessary. I built one Z6 tranny with this setup, didn't change anything else, I was just using stuff I had laying around, didn't want to spend any money on it. Seemed work well, but I only took it for one very short test drive as I didn't have the civic it went into inspected, registered or insured at the time, as a matter of fact I still don't, need to fix a hole in the floor and throw some front end parts and tires on it.
92EG8
Apr 22, 2007 12:49 PM
snatch
Jul 1, 2004 07:01 PM
Duckz
Dec 17, 2002 07:28 AM
IdotheSHOCKER
Sep 5, 2002 07:05 PM
