help! too much compression! need thicker gasket
Brief rundown: bought s2s2 cams/springs/retainers, planned on using a stock jdm gsr short block and thinner gasket along with 0.015" mill to get 11.2-1 CR to benefit from the cans. Then I decided to rebuild the bottom with jdm b16 pistons and OEM gasket to get 12:1, which in my opinion is the limit for pump gas. Well the machine shop took 0.05" off the block, standard resurfacing practice, and now I'm at 12.2:1. More importantly, I don't know where to start with the cams as for tuning. Nobody in my area knows how to degree them in, and nobody I trust can clay it.
Someone suggested using a thicker head gasket to make up for the milling, and I need help deciding which gasket to buy.
Any help would be greatly appreciated
.050" is their standard re-surfacing procedure???
Thats alot, unless you meant .005" (five thousandths).
If no-one around you knows how to degree or clay an engine, I suggest reading through HT for a few hours. Theres some good info here on how to do both procedures.
No, I meant 0.005" resurfacing, which is what they always do. Initially, I had planned on using the stock bottom end, so I had the head milled 0.015". To clarify, total milling/decking is 0.020".
My problem is selecting a gasket to negate some or all of the milling/decking procedures, along with allowing me to drop the cams in and drive the car safely, as it will need to be broken in as well as tuned
Last edited by cmross13; Aug 21, 2011 at 07:16 PM. Reason: stupid auto correct keeps changing "cams" to "cans"
As someone said before, you should be good on that with a good tune and 93 octane. Also tune it before breaking it in, lol. Just how you worded it. You always tow your car to the tuner. OEM 3 layer head gasket, not sure they make one thicker than that. Someone correct me if I'm wrong??
tunner series cams are drop in cams. just eave them at o,o and they are good to go. not if you had pro2s. different story.
I'm sorry if this comes off as if I'm being an *******, but did you read my post? I need to make up for 0.020" being cut off the block and head, as well as the huge dome of jdm b16 pistons
Yeah I've been using my phone all day and I keep forgetting to correct the auto-correct lol. I knew it was Cometic lol
so what im understanding is that if i stick the cams in at +0.5 degree each, im good to go?
They are not drop and go cams. There is a reason they need aftermarket springs and retainers and come with a Degree spec sheet. drop in cams you speak of are oem and if you did just drop in your cams and didn't degree them then you definitely aren't getting the most out of your engine.
for the OP if in doubt send your head and block to a reputable honda shop that specializes in honda performance engines and have them clay and degree your motor. trust me you'll be happier in the long run. you will need 550cc injectors to run E85 also do you have at least ectune or hondata to tune the car?.
just spoke with someone on the phone about claying it im looking at about $200 and an 8 hour round trip to Carlisle PA. i guess i'll spend the gasket money on head studs instead lol
so what im understanding is that if i stick the cams in at +0.5 degree each, im good to go?[/QUOTE]
Yes for drop in setting butt like tagperformance said. if you want the most out of it. you would need to degree them.
OP google how to clay an engine. it is simple. i have been looking for this one thread on claying a b series engine and i cant find it.
That great c-speed racing thread is no longer available. That was the best DIY combustion chamber clearance thread (clay) on the interwebz. It had full explanation and visuals.
because so much material was removed, they need to be degreed in.
Innovative Motorwerks will be doing the clay/degree. they charge $65/hr, he said 3 hours tops. John Kerr of J-K Tuning will then tune it, and we'll break it on on IMW dyno
do it yourself. heres some pics of mine. all you have to do is romove the bolt at the ends of the rocker shaft and push the rod out until the rockers on piston 1 fall out. remove the small vtec pin and put an air soft pellet in to help slide vtec into place. place rockers back onto shaft and replace bolts at the end of the shaft. reassemble motor with clay in the valve reliefs and turn your motor over twice until back to tdc. remove head and measure. it took me 2 hours to clay mine twice.
pics of the clay before and after i knotched my valve reliefs. it was my first time to clay a motor. very very easy and a good way to learn the b series head inside and out. not much to assemble a head. just gotta have the ***** to try. lmk if you need any more pics i can take for you like how to remove the rocker shaft. cheers.
Sorry I had to
