Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Dripping on Honda Civic
Old Aug 21, 2011 | 11:18 AM
spartan85's Avatar
Default Dripping on Honda Civic
Have an 06 Reg, Honda Civic iVtec Sport 5 door.
Noticed wet patch under rear passenger door on the drivers side. The drips appear to be coming from the door, there is no dampness inside except drips on the inside panel that the door covers when closed.
Is this normal?
Old Aug 21, 2011 | 02:06 PM
97emsedan's Avatar
Default Re: Dripping on Honda Civic
Need better data, is the wetness inside the car? Is the door gasket torn? Is there any damage to the door? Does the window trim seal against rain? When did you notice the wetness, after a rainstorm, or after washing the car? Be specific, please.
Old Aug 22, 2011 | 12:24 AM
spartan85's Avatar
There is no wetness inside the car or damage to the car.
The drip appears to be coming from the bottom of the actual door (around the rubber circular black thing) then dripping down on to the outside skirt of the car.
The wet patch can be seen after parking even when it hasn't rained, such as this morning.
Old Aug 22, 2011 | 02:48 AM
spartan85's Avatar
This is a european (UK) honda civic if that helps.
Old Aug 23, 2011 | 05:25 PM
97emsedan's Avatar
Ok, here is an oddball question. Is it really warm over there right now? If so, you could be getting condensation inside your door skins, and they are draining out from the drain holes at the bottom of the door skin. Other than that, I am stumped...
Old Aug 26, 2011 | 10:02 AM
Dprince's Avatar
all fluids are colored for this exact problem. if its clear dont worry just probably condensation.
if it has a color please post it. smell... ect... just dont taste it.
Old Aug 27, 2011 | 06:46 AM
bee guz's Avatar
I would check to see if the door drains are open,also some cars are shipped with rubber plugs that should have been removed by the dealer.
the door should drain to the outside just outside the weatherstrip, all cars get some water inside the doors after a heavy rain or washing.
Old Aug 29, 2011 | 05:09 AM
spartan85's Avatar
Thanks for the replies.
Checked on another forum and found the issue. B
Bee Guz you were right, basically after heavy rain opened the door and heard sloshing from within door, it still had the rubber bungs on at the bottom, upon removal a significant amount of water drained from the door. Left the bungs off and never had an issue since.
But one question , why were the bungs on in the first place? Could permanently removing them not cause future issues?
Old Aug 29, 2011 | 07:05 PM
MiX's Avatar
MiX
I bet its your a/c drainage and its just clogged or leaking into another area maybe.
Old Aug 30, 2011 | 06:45 AM
bee guz's Avatar
I'm not sure if it's a plot buy the manufactures or just lazy dealers, but since the late 60's when I started working on cars I have removed tons of those plugs from all type cars.
but why they are put in is a mystery to me, maybe they have problem and want to keep ants out of the doors.
Kevin420
Apr 24, 2017 10:31 AM
YKPhil
Jan 7, 2013 02:23 PM
tc2006
May 27, 2010 08:12 PM
