Someone broke my ignition system. Does it have to go to dealer?
Old Aug 21, 2011 | 09:53 AM
Low_bias's Avatar
Default Someone broke my ignition system. Does it have to go to dealer?
Hey guys. Someone broke into my '98 Accord last night. They cut off the trim around the steering column and bashed the crap our of the area around the ignition system. Even the cast aluminum piece is broken, as are a lot of the electronic bits around there. Is this something that requires the dealer to fix, since it involves security electronics and re-keying (the key has a chip in it), or can any shop fix this? Or, how hard is the to DIY?
Old Aug 21, 2011 | 10:10 AM
FF for Life's Avatar
Default Re: Someone broke my ignition system. Does it have to go to dealer?
Your accord has an Immobilizer system, your going to need a new lock cylinder and key to match (the new lock cylinder will come with 2 keys). If the plastic Immobilizer ring around your lock cylinder is damaged (and it definatly is), it will need replaced as well. The dealer has to program your new key and immobilizer system with the Honda factory scan tool. Technically you could replace these parts yourself but you wont be able to drive the car until the Immobilizer programing is done. The lock cylinder itself is bolted to the steering column with sheer bolts (bolts where the head breaks off when enough torque is applied to them) as a theft deterent. I would take it to the dealer.
Old Aug 21, 2011 | 10:14 AM
Low_bias's Avatar
Thanks. The key cylinder was on the floor and still turns freely.
Someday*
May 4, 2019 11:52 PM
mucjbpe
May 8, 2014 06:38 PM
reddragon93
Apr 1, 2008 08:09 PM
RochesterD16T
Jun 18, 2007 05:26 AM
plikit
Jan 2, 2006 10:24 AM
