1989 EF Sedan start up Whine
Old Aug 20, 2011 | 10:21 PM
macmac89's Avatar
Default 1989 EF Sedan start up Whine
http://youtu.be/F85-NaJaYFQ
Old Aug 21, 2011 | 06:19 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: 1989 EF Sedan start up Whine
Easy - the starter is starting to stick... The gear is still spinning while retracted... If you start hearing grinding noises after it starts it is sticking extended...
Solution - change your starter before you end up getting stranded somewhere...
rbwdriven's Avatar
the intial whine is your starter dragging.
Old Aug 21, 2011 | 05:02 PM
macmac89's Avatar
okay. also the car is running under 500rpms and it lost power. I bought new spark plug wires and plugs. still did the same thing too
DannyBoy310
Nov 10, 2011 06:53 AM
LaosBoyz25
11
Apr 19, 2007 08:10 PM
Exempt
Aug 26, 2005 01:00 PM
blueR87
Aug 2, 2005 09:16 AM
HybridGSR1
Jul 13, 2004 02:16 AM
