HELP: broken bolt connecting upper control arm to hub assembly
Ok, here's the situation. The bolt connecting the upper control arm to the rear passenger hub assembly broke and is stuck in the nut. Can the nut be taken off? If not then should I drill the bolt out or get a new hub assembly?
You can cut the nut off (usually you can just use a socket and breaker bar to break the nut off where it's welded, get a new bolt and nut, you'll probably also need to drill or beat a piece of bolt out of the upper control arm bushing as well.
allums34
Apr 13, 2011 09:55 AM
IggDawg
Nov 20, 2003 06:25 PM
