OBD1 ecu jumper wiring ?
Old Aug 20, 2011 | 03:50 PM
91efbluehatch's Avatar
Default OBD1 ecu jumper wiring ?
so i finally got off my lasy *** and went ahead and started on the ECU side of the conversion.
i swapped the wires around. added two wires to wire up to my injectors, and i also ran the small group of wires from my engine bay to my ecu.
now i have ALL the wires labeled so i didnt have to keep referring to my laptop.
but now i was wondering if someone had pics of the actualy wiring process **as in how the wires were ran, what SPECIFIC plugs they go to**
i know i have 2 wires for VTEC. and i was wanting to use a plug from a DA harness to wire into it.
One is for the switch, one is for the solenoid.
Now the question i have is do i run one of two black ground wires to the VTEC solenoid??
IF ANYONE HAS PICTURES OF THE WIRES RAN, AND WIRED UP TO THE SENSORS IT WOULD REALLY HELP!!
i tend to work better with well written directions and pictures
thanks!
Old Aug 20, 2011 | 04:06 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: OBD1 ecu jumper wiring ?
What are you even talking about? It is so simple a r... nevermind... The VTEC Solenoid gets one wire wire from ECU and it is +12v... The VTEC pressure switch is one side to ECU and the other to ground... The knock sensor is 1 wire... This has been covered thousands of times and is a cakewalk. We can't say what your wires are for the OBD-1 conversion used because it could be any brand "X" harness and even if it is a brand name harness they could use any color they want for any pinout they want...
Old Aug 21, 2011 | 06:14 PM
ok you absolutely didnt answer any of my questions! lol
and i know it is so simple a retard can do it. but i guess i could always rush into things, and then make a post in a week saying "OBD1 CONVERSION done, B16 throwing code 4,743,649!!!" but no thats not what i want.
im taking my time, RESEARCHING for hours. I have my laptop RIGHT next to me whenever i am doing the wiring.
i know what wires go where. what i am asking is how do some of the people run the ground wires FROM the jumper harness.
all i was asking is HOW and WHERE do people normally run the wires and how do they have them wired up
Old Aug 21, 2011 | 06:21 PM
crx_si-r's Avatar
which ground wires are you referring to? regular ground or logic grounds (used for shielded wires)?
Old Aug 21, 2011 | 06:25 PM
i believe it would have to be regular grounds.
in the jumper the group of wires you run to the engine bay there are three wires mainly used for grounds. two black, and one brown.
what my question is, is how do you specifically run these grounds. i know on the VTEC pressure switch, it uses a ground wire. so there fore i should be able to wire that right into the switch along with the (+) wire correct?
Old Aug 21, 2011 | 06:51 PM
crx_si-r's Avatar
yes, or you can just run the ground straight to the thermostat housing
Old Aug 21, 2011 | 07:02 PM
i think it would look cleaner if i ran it to the sensor. dont you?
Old Aug 21, 2011 | 07:09 PM
crx_si-r's Avatar
im confused? the ground wire coming off the vtec oil pressure sensor is normally grounded at the thermostat housing either way. if you want a clean install then i would suggest you splice it into the stock thermostat ground. i use a block off plug which has 2 sections. i run all my power wires and ground wires there on my stock style harnesses that i make, like in the pics below. on my tuck harnesses i use a similar style plug. less soldered wires together, means a less bulky harness.
Old Aug 21, 2011 | 07:12 PM
crx_si-r's Avatar
the vtec oil sensor has 2 wires. 1 is a ground, which is spliced into the other ground wires going to the thermostat housing. the 2nd wire is a signal wire which goes directly to the ecu. so im confused when you say it would look cleaner if it ran directly to the sensor?
Old Aug 21, 2011 | 08:11 PM
Sorry guess I worded that wrong. I PM'd you about wiring in a two wire plug for the pressure switch itself. I run the wire from the ecu to the switch. And then run the switch ground to the thermostat housing? And also that block off plug you ran all the power wires from all the added sensors to the distribution block and ran the grounds there as well?
Old Aug 21, 2011 | 08:17 PM
crx_si-r's Avatar
you got it. the normal block off plug that is used by obd1+2 cars is normally an 8 pin, but the one i use is 14 pin. 2 sections each with 7 pins and they are split right down the middle. i like it a lil better this way.
Old Aug 22, 2011 | 05:13 AM
Ok I totally see it now. Where can I get that white plug to use for my power sensor wires? Also those yellow wires pinned into the gray plug are those the ones left over from the injector distribution block
Old Aug 22, 2011 | 05:50 AM
crx_si-r's Avatar
Power Sensor Wires??? do you mean signal wire? are you referring to the single wire on the vtec solenoid? if so, its a very common plug on our cars. take a look at your EVAP plug and you will see one there, as well as in your door. just run to the junkyard and snag one that matches up.
Old Aug 22, 2011 | 05:56 AM
crx_si-r's Avatar
those yellow wires are for:
Idle Air Control Valve
Injectors
and o2 sensor
Old Aug 22, 2011 | 08:26 PM
Injectors
and o2 sensor
oh ok lol.
is this all what you meant by how you convert a harness and make it a true OBD1 harness
Old Aug 22, 2011 | 09:59 PM
crx_si-r's Avatar
yup. i run the wiring exactly like an obd1 car
EGCIVICKING95
Aug 30, 2011 05:03 AM
DougNuts
16
Jul 11, 2005 07:27 AM
hybrid1990crx
Nov 21, 2004 09:14 AM
Bseriesy0
Sep 21, 2004 10:14 AM
Project92Hatch
Mar 26, 2003 01:22 PM
