98 accord 4cyl sputtering problem
Old Aug 20, 2011 | 03:44 PM
Kanevo's Avatar
Default 98 accord 4cyl sputtering problem
Hi guys,
I'm new to this forum and would really appreciate some help troubleshooting a problem that I am having with my accord. I'm going to be as specific as I can so please bear with me. To start its a 98 4cyl manual with about 215K miles, cai, tb spacer, full exhaust including header. The problem is that in the range of 1,200 and 2,000 rpms it is sputtering as if it does not have enough fuel. This problem only occurs when I am cruising in that rpm range ex. 35mph in 4th gear and does not always happen but is frequent. When I accelerate/decelerate through this rpm range there is no sputter. My car does have hard starts occasionally. What I've attempted to fix said problem is change cap and rotor, ignition coil, spark plugs twice(currently have ngk), checked resistance on spark plug wires(checked out fine), front O2 sensor, fuel pressure regulator, fuel pump and seafoam. There is no check engine light. If anyone can please help I would fully appreciate it. Thank you!
Old Aug 20, 2011 | 04:45 PM
Roader's Avatar
Default Re: 98 accord 4cyl sputtering problem
Originally Posted by Kanevo
Hi guys,
...1,200 and 2,000 rpms it is sputtering as if it does not have enough fuel. This problem only occurs when I am cruising in that rpm range...
EGR ports clogged?
https://honda-tech.com/forums/honda-accord-1990-2002-2/diy-fix-all-had-p0401-code-2674082/
Mine were and it never threw a CEL, but I have the earlier engine.
Old Aug 20, 2011 | 05:37 PM
Kanevo's Avatar
Thank you for your response. I actually cleaned that out about a year ago because I was have egr problems and that problem has been resolved since I cleaned it.
Old Aug 21, 2011 | 07:42 PM
Kanevo's Avatar
Anybody else know what it may be?
Old Aug 21, 2011 | 09:52 PM
See_Bye's Avatar
Check to see if your iac valve is plug. I have the same problem since I unplug mine until I can convert it to a 2 wire One instead.
Old Aug 21, 2011 | 09:54 PM
See_Bye's Avatar
But it some thing to do with your throttle body or intake manifold. Do you have any CEL ?
Old Aug 21, 2011 | 11:05 PM
Kanevo's Avatar
I have no cel. Looks like I'll have to take off my iac valve and see if it needs a cleaning or check if its faulty. Thank you for your help! I'll take it off and post back if it solves the issue or not.
Old Aug 22, 2011 | 04:16 PM
poorman212's Avatar
Did you clean the valve or the chamber....or both.....does this only happen once the car temp is "normal"?
Old Aug 22, 2011 | 05:27 PM
Kanevo's Avatar
I cleaned the iac valve/chambers and manifold plenum space although the gasket for the iac valve is now allowing leakage after reassembly(this is why people should never re use gaskets). I'm now waiting to receive the part tomorrow from the dealership, and then I will be able to see if the problem is resolved. This problem occurs when the car is cold and warmed up.
HondaNFS
Jun 6, 2017 07:13 AM
bigoaks
Oct 5, 2010 12:24 PM
Milano-ITR
Feb 13, 2010 08:39 AM
honda_bg
Mar 7, 2008 09:57 AM
1320performancefreak
Feb 25, 2006 07:17 PM
